CAN Filter MCP2515 not working
Hey Guys, i know i know there r already a lot of threads open for this problem but i have read them all and still cant figure out what i have done wrong.
So im trying to filter out 0x150, 0x151 and 0x361. I have set both masks and the filters -> in the monitor it says filter initialized successfully but when i then send my CAN signals all of them are showing up in my monitor.
This is my code:
#include <SPI.h>
#include <mcp_can.h>
// Initialisierung des CAN-Bus auf dem MCP2515-Modul
MCP_CAN CAN(10);
  // Initialisierung des MCP2515
  if(CAN.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK) {
    Serial.println("CAN-Bus initialisiert");
    CAN.setMode(MCP_NORMAL);
    Serial.println("Fehler bei der Initialisierung des CAN-Bus");
    while(1);
  CAN.init_Mask(0, 0, 0x1ff);              // Init first mask (Std CAN. No masking applied)
  CAN.init_Filt(0, 0, 0x150);              // Init first filter...
  CAN.init_Filt(1, 0, 0x151);              // Init second filter...
  CAN.init_Mask(1, 0, 0x3ff);              // Init second mask (Std CAN. No masking applied)
  CAN.init_Filt(2, 0, 0x361);              // Init third filter...
  //CAN.init_Filt(3, 0, 0x01);              // Init fourth filter...
  //CAN.init_Filt(4, 0, 0x01);              // Init fifth filter...
  //CAN.init_Filt(5, 0, 0x01);              // Init sixth filter...
  // Prüfung auf eingehende CAN-Nachrichten
  if(CAN_MSGAVAIL == CAN.checkReceive()) {
    // Empfangen einer CAN-Nachricht
    unsigned char len = 0;
    unsigned char buf[8];
    unsigned long canId = 0;
    CAN.readMsgBuf(&canId, &len, buf);
    Serial.print("CAN-Nachricht empfangen - ID: ");
    Serial.print(canId, HEX);
    Serial.print(" Länge: ");
    Serial.print(len);
    Serial.print(" Daten: ");
    for(int i = 0; i < len; i++) {
      Serial.print(buf[i], HEX);
      Serial.print(" ");
There's a flaw in the chip that requires you to treat 11 bit addresses as 29 bit addresses.
Here's an example for a range of IDs from 07E8 to 07ED.
Modify to suit the IDs you require.
// There are two independent receive paths.
// Path 0 (RXB0 in the datasheet) has a mask and two filters labelled 0 and 1.
// Path 1 (RXB1 in the datasheet) has a mask and four filters labelled 2 to 5.
// The messages received by the two paths are combined and sent to the Arduino.
CAN0.init_Mask(0,0,0x07FF0000); // check all 11 address bits for RXB0
CAN0.init_Filt(0,0,0x07E80000); // Allow 07E8 through RXB0.
CAN0.init_Filt(1,0,0x07E90000); // Allow 07E9 through RXB0
CAN0.init_Mask(1,0,0x07FF0000); // check all 11 address bits for RXB1
CAN0.init_Filt(2,0,0x07EA0000); // Allow 07EA through RXB1
CAN0.init_Filt(3,0,0x07EB0000); // Allow 07EB through RXB1
CAN0.init_Filt(4,0,0x07EC0000); // Allow 07EC through RXB1
CAN0.init_Filt(5,0,0x07ED0000); // Allow 07ED through RXB1
so i just have to add the 0000 behind my IDs
like that?
  CAN.init_Mask(0, 0, 0x1ff0000);              // Init first mask (Std CAN. No masking applied)
  CAN.init_Filt(0, 0, 0x1500000);              // Init first filter...
  CAN.init_Filt(1, 0, 0x1510000);              // Init second filter...
  CAN.init_Mask(1, 0, 0x3ff0000);              // Init second mask (Std CAN. No masking applied)
  CAN.init_Filt(2, 0, 0x361000);              // Init third filter...
  //CAN.init_Filt(3, 0, 0x010000);              // Init fourth filter...
Copy the masks as I have shown.
Hey, so i copied the code exactly as u gave me which means i should only see IDs from 07E8 to 07ED, but all other messages r also going trough.
Also u wrote " CAN0. init_mask....." but it can only compile with "CAN. init_mask...." so without the 0 after CAN. Maybe it was just a typo or something is wrong on my end.
code:
#include <SPI.h>
MCP_CAN CAN(10);
    while(1);
CAN.init_Mask(0,0,0x07FF0000); // check all 11 address bits for RXB0
CAN.init_Filt(0,0,0x07E80000); // Allow 07E8 through RXB0.
CAN.init_Filt(1,0,0x07E90000); // Allow 07E9 through RXB0
CAN.init_Mask(1,0,0x07FF0000); // check all 11 address bits for RXB1
CAN.init_Filt(2,0,0x07EA0000); // Allow 07EA through RXB1
CAN.init_Filt(3,0,0x07EB0000); // Allow 07EB through RXB1
CAN.init_Filt(4,0,0x07EC0000); // Allow 07EC through RXB1
CAN.init_Filt(5,0,0x07ED0000); // Allow 07ED through RXB1
    Serial.print("CAN-Message received - ID: ");
    Serial.print(len);
      Serial.print(" ");
Use MCP_STDEXT instead of MCP_ANY
That puts it into 29 bit mode.
MCP_ANY disables masks and filters.
works like a charm now thank u so much man <3
Thank you so much for your help!!!!
