#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
MCP_CAN CAN0(9);
if (CAN0.begin(MCP_STDEXT, CAN_250KBPS, MCP_16MHZ) == CAN_OK) Serial.print("MCP2515 Init Okay!!\r\n");
else Serial.print("MCP2515 Init Failed!!\r\n");
pinMode(2, INPUT); // Setting pin 2 for /INT input
CAN0.init_Mask(0, 1, 0x1FFFFFFF); // Init first mask...
CAN0.init_Filt(0, 1, 0x18FF0108); // Init first filter...
CAN0.init_Filt(1, 1, 0x18FF0208); // Init second filter...
CAN0.init_Mask(1, 1, 0x1FFFFFFF); // Init second mask...
CAN0.init_Filt(2, 1, 0x18FF0308); // Init third filter...
CAN0.init_Filt(3, 1, 0x00000000); // Disable fourth filter...
CAN0.init_Filt(4, 0, 0x00000000); // Disable fifth filter...
CAN0.init_Filt(5, 0, 0x00000000); // Disable sixth filter...
Serial.println("MCP2515 Library Mask & Filter Example...");
CAN0.setMode(MCP_NORMAL); // Change to normal mode to allow messages to be transmitted
if (!digitalRead(2)) // If pin 2 is low, read receive buffer
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
Serial.print("ID: ");
Serial.print(rxId, HEX);
Serial.print(" Data: ");
for (int i = 0; i < len; i++) // Print each byte of the data
if (rxBuf[i] < 0x10) // If data byte is less than 0x10, add a leading zero
Serial.print("0");
Serial.print(rxBuf[i], HEX);
Serial.print(" ");
Issue with above code : I expect to read values for 0x18FF0108 , 0x18FF0208, 0x18FF0308. I am effectively filtering the IDs but the Serial monitor prints the IDs as 0x98FF0108 , 0x98FF0208, 0x98FF0308.
What mistake am i doing in setting the Mask ?
