Can i convert my current code here to work with Firestore?
I have tried to find some other library that could help me convert this code to work with Firestore, but i couldn't find any, as you see i'm using Firebase_ESP_Client i tried to convert the code to work with firestore but it did not work, so has anyone worked with firestore and can help me convert this code to work with firestore instead of real-time database?
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <Firebase_ESP_Client.h>
#include <addons/TokenHelper.h>  //Provide the token generation process info.
#include <addons/RTDBHelper.h>   //Provide the RTDB payload printing info and other helper functions.
/* 1. Define the WiFi credentials */
//#define WIFI_SSID "Abdallah Agha"
//#define WIFI_PASSWORD "abdallah123"
/* 2. Define the API Key */
#define API_KEY "*******************"
/* 3. Define the RTDB URL */
#define DATABASE_URL "***********************"
/* 4. Define the user Email and password that alreadey registerd or added in your project */
#define USER_EMAIL "jopetrol@test.com"
#define USER_PASSWORD "123456"
#define USONIC_DIV 0.034
//Define Firebase Data object
FirebaseData stream;
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
String uid;
String path;
const int trigPin = D1;
const int echoPin = D2;
long duration;
int oldDistance;
#define PUMP1 2
//#define PUMP2 4
//SENSOR
int readDistance() {
  long dur;
  long dis;
  int percentage;
  // Transmitting pulse
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Waiting for pulse
  dur = pulseIn(echoPin, HIGH);
  dis = dur * USONIC_DIV/2;
  //190cm (2500L) is our 0 percentage: ya3ni bs yosal mostawa el mai lal 218cm (ya3ni bs yeb3ed 3an el sensor 218cm) hek el tank bkoon fedi
  //30 is our 1800 percentage: ya3ni lama etgareb el mai w tseer bainha w bean el sensor 30cm hek full
  //percentage = map(dis, 218, 20, 0, 1800);
  //190cm (2500L) is our 0 percentage: ya3ni bs yosal mostawa el mai lal 200cm (ya3ni bs yeb3ed 3an el sensor 200cm) hek el tank bkoon fedi
  percentage = map(dis, 190, 30, 0, 2500);
  if(percentage < 0){
    percentage = 0;
  } else if (percentage > 2500){
    percentage = 2500;
  return percentage;
//Firebase RTDB Sensor
bool setDistanceValue(int distance) {
  // RTDB mainTankLitersAmount
  path = "users/" + uid + "/roofTanks" "/1" "/mainTankLitersAmount";
  Serial.print("Update sensor state as int... " );
  if (Firebase.RTDB.set(&fbdo, path.c_str(), distance)) {
    Serial.println("ok");
    return true;
  Serial.println(fbdo.errorReason().c_str());
  return false;
// This is the callback function called when stream from firebase was received (every time data has changed)
void streamCallback(FirebaseStream data)
  Serial.println("\nStream data available...");
  Serial.println("STREAM PATH: " + data.streamPath());
  Serial.println("EVENT PATH: " + data.dataPath());
  Serial.println("DATA TYPE: " + data.dataType());
  Serial.println("EVENT TYPE: " + data.eventType());
  if (data.dataType() == "boolean")
    digitalWrite(PUMP1, data.boolData());
  if (data.dataType() == "string")
    if (data.stringData() == "on") {
      digitalWrite(D0, HIGH);
      Serial.println("Sensor ON");
      // Update RTDB online data about sensor distance
      int distance = readDistance();
      setDistanceValue(distance);
    if (data.stringData() == "off") {
      digitalWrite(D0, LOW);
      Serial.println("Sensor OFF");
void streamTimeoutCallback(bool timeout)
  if (timeout)
    Serial.println("stream timed out, resuming...\n");
  if (!stream.httpConnected())
    Serial.printf("error code: %d, reason: %s\n\n", stream.httpCode(), stream.errorReason().c_str());
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  pinMode(PUMP1, OUTPUT);
//-------------------Wifi Manager Work-----------------
  WiFiManager wifiManager;
  wifiManager.autoConnect("i-Device");
  Serial.println("Connectted....");
  Serial.printf("Firebase Client v%s\n\n", FIREBASE_CLIENT_VERSION);
  /* Assign the api key (required) */
  config.api_key = API_KEY;
  /* Assign the user sign in credentials */
  auth.user.email = USER_EMAIL;
  auth.user.password = USER_PASSWORD;
  /* Assign the RTDB URL (required) */
  config.database_url = DATABASE_URL;
  /* Assign the callback function for the long running token generation task */
  config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
  Firebase.begin(&config, &auth);
  Firebase.reconnectWiFi(true);
  //Recommend for ESP8266 stream, adjust the buffer size to match your stream data size
  stream.setBSSLBufferSize(2048 /* Rx in bytes, 512 - 16384 */, 512 /* Tx in bytes, 512 - 16384 */);
  // Getting the user UID might take a few seconds
  Serial.println("Getting User UID");
  while (auth.token.uid == "") {
    Serial.print('.');
  // Print user UID
  uid = auth.token.uid.c_str();
  Serial.print("User UID: ");
  Serial.println(uid);
  path = "users/" + uid;
  // Set the stream callback (every change in data related to path, will trig the callback function)
  if (!Firebase.RTDB.beginStream(&stream, path.c_str()))
    Serial.printf("sream begin error, %s\n\n", stream.errorReason().c_str());
  Firebase.RTDB.setStreamCallback(&stream, streamCallback, streamTimeoutCallback);
  // Write some test data in RTDB
  //ESP LIGHT (PUMP 1)
  if (Firebase.ready())
    //RTDB espLight
    path = "users/" + uid + "/roofTanks" "/1" "/espLight";
    Serial.print("Set initial espLight state as bool... " );
    if (Firebase.RTDB.setBool(&fbdo, path.c_str(), true))
    //RTDB status
    path = "users/" + uid + "/roofStatus" "/status";
    Serial.print("Set initial roof tank state as int... " );
    if (Firebase.RTDB.setString(&fbdo, path.c_str(), "on"))
    Serial.print("Set initial sensor state as int... " );
  // Check distance, if value is different from last state, update RTDB
  // In order to avoid continuous writing at every minimum variation,
  // is possible to define a minimum offset for example 1%)
  int distance = readDistance();      // get actual distance
 // if (abs(distance - oldDistance) > 1 )
   if (abs(distance - oldDistance) > 1  &&  digitalRead(D1) )   // check also if sensor is enabled
     oldDistance = distance;
     setDistanceValue(distance);      // Send to RTDB only if change
  // Need to be called in order to check if stream data is avalaible
    if (!Firebase.RTDB.readStream(&fbdo))
      Serial.printf("sream read error, %s\n\n", fbdo.errorReason().c_str());
    if (fbdo.streamTimeout())
      if (!fbdo.httpConnected())
        Serial.printf("error code: %d, reason: %s\n\n", fbdo.httpCode(), fbdo.errorReason().c_str());
Firebase ESP Client is compatible with Cloud Firestore.
Check examples:
Unfortunately their Firestore components does not support streamCallback functions :disappointed:
Their Firebase RTDB is working perfectly as you see in my code, it is great choice but just for testing and if there will be a few users that will never go above 10GB downloads (how the real-time data base CRUD works they call it downloads) a month then it's okay to use it, but if you're project is already got in between 100 - 1k users then RTDB is not a good choice and going to be really expensive.
So i think i will keep searching and see how other friends here in the Arduino forum does it or recommend to do it in the best practice.
