this is my arduino code for esp8266 . i have used firebaseClient library. i encounter errors after compiling. my goal is to take data from a device using esp and display on mobile app. here i have tried to implement esp8266 code using firebaseclient library
#include <ESP8266WiFi.h>
#include <FirebaseClient.h>
// Wi-Fi credentials
const char* ssid = "Redmi ";
const char* password = "vogu";
// Firebase configuration
FirebaseClient client ("https://< >.firebaseio.com"); // Replace with your Firestore URL
//connect to wifi
WiFi.begin(ssid, password);
Serial.print("Connecting to Wifi");
Serial.print(".");
Serial.println("Connected to Wi-Fi");
void writeData(float waterLevel) {
String documentPath = "sensors/water_level"; // Firestore document path
String jsonData = "{\"level\": " + String(waterLevel) + "}"; // JSON data format
if (client.post(documentPath, jsonData)) {
Serial.println("Data sent successfully");
Serial.println("Error sending data: " + client.error());
void readData() {
if (client.get(documentPath)) {
Serial.println("Data retrieved: " + client.responseBody());
Serial.println("Error reading data: " + client.error());
// Placeholder for sending and receiving data
// Example of how to call the functions
writeData(75.5); // Example water level
delay(10000); // Wait for 10 seconds
readData(); // Read the data
delay(10000); // Wait for another 10 seconds
C:\Users\<-->\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino:9:70: error: no matching function for call to 'firebase::FirebaseClient::FirebaseClient(const char [44])' 9 | FirebaseClient client ("https://< >.firebaseio.com"); // Replace with your Firestore URL | ^ In file included from C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino:2: c:\Users\< >\Documents\Arduino\libraries\FirebaseClient\src/FirebaseClient.h:128:9: note: candidate: 'firebase::FirebaseClient::FirebaseClient()' 128 | FirebaseClient() {} | ^~~~~~~~~~~~~~ c:\Users\< >\Documents\Arduino\libraries\FirebaseClient\src/FirebaseClient.h:128:9: note: candidate expects 0 arguments, 1 provided In file included from C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino:2: c:\Users\< >\Documents\Arduino\libraries\FirebaseClient\src/FirebaseClient.h:87:11: note: candidate: 'constexpr firebase::FirebaseClient::FirebaseClient(const firebase::FirebaseClient&)' 87 | class FirebaseClient : public AppBase | ^~~~~~~~~~~~~~ c:\Users\< >\Documents\Arduino\libraries\FirebaseClient\src/FirebaseClient.h:87:11: note: no known conversion for argument 1 from 'const char [44]' to 'const firebase::FirebaseClient&' C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino: In function 'void writeData(float)': C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino:28:16: error: 'class firebase::FirebaseClient' has no member named 'post' 28 | if (client.post(documentPath, jsonData)) { | ^~~~ C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino:31:56: error: 'class firebase::FirebaseClient' has no member named 'error' 31 | Serial.println("Error sending data: " + client.error()); | ^~~~~ C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino: In function 'void readData()': C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino:37:16: error: 'class firebase::FirebaseClient' has no member named 'get' 37 | if (client.get(documentPath)) { | ^~~ C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino:38:52: error: 'class firebase::FirebaseClient' has no member named 'responseBody' 38 | Serial.println("Data retrieved: " + client.responseBody()); | ^~~~~~~~~~~~ C:\Users\< >\AppData\Local\Temp\.arduinoIDE-unsaved2024917-11596-xn4egq.2i22\sketch_oct17a\sketch_oct17a.ino:40:56: error: 'class firebase::FirebaseClient' has no member named 'error' 40 | Serial.println("Error reading data: " + client.error()); | ^~~~~ exit status 1 Compilation error: no matching function for call to 'firebase::FirebaseClient::FirebaseClient(const char [44])'
