Can I use const chars and integers together?
I'd like to send a tweet using ethernet shield and found an example code in library. But it only allows me to send a predetermined const char such as this: "Hello World". I'd like to squeeze some integers in between the text. I have a DHT22 temp and humidity sensor with me and I'd like to send a tweet like "My room humidity is: 50% and my room temp is 23C". Is there a simple way to use both integers and const chars to feed my tweet? Here's the example code btw:
// Twitter client sketch for ENC28J60 based Ethernet Shield. Uses
// arduino-tweet.appspot.com as a OAuth gateway.
// Step by step instructions:
//  1. Get a oauth token:
//     http://arduino-tweet.appspot.com/oauth/twitter/login
//  2. Put the token value in the TOKEN define below
//  3. Run the sketch!
//  WARNING: Don't send more than 1 tweet per minute!
//  NOTE: Twitter rejects tweets with identical content as dupes (returns 403)
#include <EtherCard.h>
// OAUTH key from http://arduino-tweet.appspot.com/
#define TOKEN   "Insert-your-token-here"
// ethernet interface mac address, must be unique on the LAN
byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
const char website[] PROGMEM = "arduino-tweet.appspot.com";
static byte session;
byte Ethernet::buffer[700];
Stash stash;
static void sendToTwitter () {
  Serial.println("Sending tweet...");
  byte sd = stash.create();
  const char tweet[] = "@solarkennedy the test Twitter sketch works!";
  stash.print("token=");
  stash.print(TOKEN);
  stash.print("&status=");
  stash.println(tweet);
  stash.save();
  int stash_size = stash.size();
  // Compose the http POST request, taking the headers below and appending
  // previously created stash in the sd holder.
  Stash::prepare(PSTR("POST http://$F/update HTTP/1.0" "\r\n"
    "Host: $F" "\r\n"
    "Content-Length: $D" "\r\n"
    "\r\n"
    "$H"),
  website, website, stash_size, sd);
  // send the packet - this also releases all stash buffers once done
  // Save the session ID so we can watch for it in the main loop.
  session = ether.tcpSend();
void setup () {
  Serial.begin(57600);
  Serial.println("\n[Twitter Client]");
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println(F("Failed to access Ethernet controller"));
  if (!ether.dhcpSetup())
    Serial.println(F("DHCP failed"));
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
  if (!ether.dnsLookup(website))
    Serial.println(F("DNS failed"));
  ether.printIp("SRV: ", ether.hisip);
  sendToTwitter();
void loop () {
  ether.packetLoop(ether.packetReceive());
  const char* reply = ether.tcpReply(session);
  if (reply != 0) {
    Serial.println("Got a response!");
    Serial.println(reply);
Have a look at the printf() function.
UKHeliBob:
Or the sprintf() function.
That too, of course :slight_smile:
Or better still, the sprintf_P function
Or even snprintf_P.
Do I have to replace some files in the Arduino directories or something to use these ?
No
printf/snprint is a bit tricky to use the first time.
Something like this should give you the general idea (untested):
   byte humidity = 50;
   byte temperature = 34;
   char buffer[60]; // large enough to hold the whole string
   snprintf(buffer, sizeof(buffer), "My room humidity is: %d%% and my room temp is %dC", humidity, temperature); // format the string we want to send
   stash.print(buffer);
FYI, although printf() is neat, you can do what you are asking for with consecutive Serial.print() calls.
To add to aarg's point, printf and his friends will use up a lot more program memory that consecutive Serial.print(...) calls.
I stumbled on this a while ago which gives you the best of both worlds:
http://arduiniana.org/libraries/streaming/
It would let you write:
Serial << F("My room temperature is ") << Temperature << F("°C, and the humidity is ") << Humidity << "%";
The F("...") will save you more program memory (right at the end).
Paul_Martinsen:
Streaming | Arduiniana
Yes, it should be included in the IDE releases.
arduinodlb:
   byte humidity = 50;
Sprintf worked great, thanks. One last thing though. In my region "%" sign comes before the number so to do that I played with characters but all I could do was breaking the code. How do I do that?
Use two %'s: "%%%d" will print a percent and then the integer.
KeithRB:
It only print the number "4". I'm sure the sensor reports a higher humidity value becaue 4 is too low. So the code is probably omitting the last digit.
Well, it's your code, and you didn't post it, so, good luck fixing it.
cagancelik:
Not likely.
But look here to see how to format printf/snprintf strings:
http://www.cplusplus.com/reference/cstdio/printf/
I am in New Mexico. 4 is about right. 8^)
