can i use same external interrupt pins for gsm shield and for hall sensor
my problem is that gsm shield uses pin 2 and pin 3 for tx and rx communication that i needed also for the hall sensor which uses also interrupt pin 3 for magnet detection, im using arduino uno board with two external interrupt pin. Is there any way that i can use same interrupt pin for different function, btw here is my code.
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
char number[]="09152715557";
char message[180];
char pos;
char *p;
void setup() //declaring inputs and outputs
attachInterrupt(digitalPinToInterrupt(3), magnet_detect, RISING);//Initialize the intterrupt pin (Arduino digital pin 2)
half_revolutions = 0;
rpm = 0;
timeold = 0;
pinMode(7, OUTPUT); //output for turning LED ON or OFF
if (gsm.begin(2400)) //condition if gsm is initialized
Serial.println("\nstatus=READY"); //displays "ready" on the serial monitor if gsm is ready
else Serial.println("\nstatus=IDLE"); //otherwise displays "idle" on the serial monitor if gsm is not found
void loop() //looping of the program
float V;
float rad;
if (half_revolutions >= 1) {
rpm = 301000/(millis() - timeold)half_revolutions;
timeold = millis();
rad=rpm
2
((23.1416)/60);
V=(3600/1000)
(0.2032rad);
Serial.print(V,DEC);
Serial.print(" kph ");
Serial.print(rpm
2);
Serial.print(" rpm ");
pos=sms.IsSMSPresent(SMS_UNREAD); //save to variable if there is an SMS
Serial.println((int)pos); //display position number (a.k.a index) of the message
if((int)pos>0&&(int)pos<=20) //if message from 0-20 is found
Serial.print("Message Received, INBOX="); //display an output on the serial monitor
Serial.println((int)pos); //display the position/index of the message
message[0]='\0'; //display '0' if no messages found
sms.GetSMS((int)pos,number,message,180); //get position/index, number of sender, and text message
Serial.println(message); //display the text on serial monitor
if(strstr(message, "ON"))
digitalWrite(7,HIGH); //if message 'ON' is received, LED is ON
if(strstr(message, "OFF"))
digitalWrite(7,LOW); //if message 'OFF' is received, LED is OFF
sms.DeleteSMS((int)pos); //after reading, delete SMS
void magnet_detect()//This function is called whenever a magnet/interrupt is detected by the arduino
half_revolutions++;
I don't have the SIM900 library so can't check, but you may be able to change the software serial pins in the library .h file. It would help if you link to the library that you are using because there seems to be more than one.
And please read the "how to use the forum" stickies for guidelines on posting here.
Im having exactly the same problem! Ive got an Uno and a tinysine GSM shield. I need to change from an integer to an interrupt so that I never miss a count but pin 2 and 3 are already used!!
A clued up friend of mine spent ages changing things around in the library etc. and we changed the jumpers to HW. But it still didn't come right, it wouldnt compile. I cant remember the full reason. I will find out and keep you updated. Still searching for a resolution
