Can I use the R4 minima as an icsp?
I picked up an R4 Uno Minima for the main purpose of programming ATTiny85s for guitar pedal bypass relays. It seems to take the ArduinoICSP sketch fine, but then fails when uploading the other sketch for the ATTiny. There's definitely a possibility I'm doing something wrong as I'm new to these things, but have used older models for the same purpose previously. I just got to thinking maybe these don't function that way?
Under tools you need to set the programmer as Arduino as ISP. When you are uploading to the ATtiny85 you will need to select the board as ATtiny25/45/85 and then the clock - internal or external and frequency. Once you have setup the board then you need to burn the bootloader and then you can compile and upload your sketch via the upload via programmer option.
I'm still not having any luck. I plug in my R4 and then upload the ArduinoISP sketch to it and get these results:
Sketch uses 58128 bytes (22%) of program storage space. Maximum is 262144 bytes.
Global variables use 4860 bytes (14%) of dynamic memory, leaving 27908 bytes for local variables. Maximum is 32768 bytes.
dfu-util 0.11-arduino4
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
Device ID 2341:0069
Run-Time device DFU version 0101
Claiming USB DFU (Run-Time) Interface...
Setting Alternate Interface zero...
Determining device status...
DFU state(0) = appIDLE, status(0) = No error condition is present
Device really in Run-Time Mode, send DFU detach request...
Device will detach and reattach...
Opening DFU USB Device...
Claiming USB DFU Interface...
Setting Alternate Interface #0 ...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 0101
Device returned transfer size 64
Copying data from PC to DFU device
Download	[=========================] 100%        58136 bytes
Download done.
DFU state(7) = dfuMANIFEST, status(0) = No error condition is present
Done!
Then I switch my board over to ATTiny85, and select the programmer as "Arduino as ISP" and then try to upload the sketch which results in:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
10 times before failing. I also get the same result if I select Burn Bootloader.
Hi @sgtrutters. I know it has been a long time but I found this topic while I was doing some research on using the UNO R4 Minima and UNO R4 WiFi boards as "Arduino as ISP" programmers and thought I should share my findings here in case you are still interested, and for the benefit of others who might find this forum topic while researching the subject.
I discovered the error you experienced was caused by a bug in the "ArduinoISP" sketch. I have fixed the bug:
The fixed version of the example will be in the next release of Arduino IDE. You can download it now here:
https://raw.githubusercontent.com/arduino/arduino-examples/1.10.1/examples/11.ArduinoISP/ArduinoISP/ArduinoISP.ino
Another thing to note is that you must select Tools > Programmer > Arduino as ISP (ATmega32U4) instead of Tools > Programmer > Arduino as ISP from the Arduino IDE menus when using an UNO R4 Minima or UNO R4 WiFi board as an "Arduino as ISP" programmer.
