Hello, I just want to know that can we use 2 Arduino IDE of different version program for operate 2 different router ?
Yes you can. You need to start two copies of the Arduino running. Not open one, and then open a 2nd sketch - has to be two instances of the IDE running, so that they show up as 2 icons on the task bar.
For example, this is IDE versiom1.8.4, with a 328P based board bootloaded as an Uno, and an actual Uno.
See the "portable" versions for that aspect.
Thanks for your information sir, now thier is another problem occur, I use Arduino Uno with V3 shield and upload grbl , blink and com port all are uploaded. G code sender software work properly I think.
For your information I want to tell you that I make a CNC router n for this I use tb6600 driver , Arduino Uno with V3 shield and power supply 12v
Will you plzz give me a proper information about wiring
That is a completely different question / issue.
I would suggest you start a completely different topic in the correct section with more details.
See the links below for more help with that.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
