ah - I missed that added information.
then indeed the arduino makes sense
Have you heard the name of an unsigned 32-bit millisCounter which starts from 0 when the Uploading of a sketch in UNO is done and then it advances each count at 1 ms interval on interrupts?
The content of millisCounter can be read (on-the-fly) at any time using millis() function. Sample codes to blink L (onboard LED of UNO) at 1-sec interval using millis()/millisCounter:
unsigned long presentMillis = millis(); //record current time
int ledState = LOW;
pinMode(13, OUTPUT);
digitalWrite(13, ledState); //LED is off
if (millis() - presentMillis >= 1000) //1000 ms
ledState = !ledState;
presentMillis = millis(); //record current elapsed time
//do some other tasks
Thank you. I was not aware of the feature and I will look into it. Thank you for the tip and code.
I will look at that now. Thanks so much for the getting me started.
