Can some one help me with my code
i was trying to make a guessing game and I got all the code in but it gave me an error error: expected initializer before 'if'
exit status 1
if(Serial.available()>0){
guess = Serial.read();
Serial.print("Your guess ");
Serial.println(guess);
guess=guess-48;
You might be missing a semicolon somewhere, but without seeing more of the code it'll be hard to pinpoint the error.
Try looking at the error message for a line indicator (something like programName:x:y: error: ..., then go to line x and look around for missing punctuation or other synthax errors.
You seem to be missing the '{' that marks the start of the body of loop().
il try that
here is the full code
char guess;
int secret_num=random(0, 9);
void setup(){
pinMode(13, OUTPUT);
pinMode(11, OUTPUT);
pinMode(9, OUTPUT);
Serial.println("Istructions: Guess numbers form 0to9");
void loop(){
guess=guess-48;
if(guess > secret_num){
Serial.println("too high!");
digitalWrite(13,high);
Serial.println("Guess again:");
delay(300);
digitalWrite(13,LOW);
else if (guess < secret_num){
Serial.println("Too low!");
digitalWrite(11,high);
delay(300);
digitalWrite(11,LOW);
else{
Serial.println("Correct!");
digitalWrite(9,high);
delay(300);
digitalWrite(9,LOW);
after adding the { i got more errors
In function 'void loop()':
27:21: error: 'high' was not declared in this scope
27:21: note: suggested alternative: 'sinh'
35:21: error: 'high' was not declared in this scope
35:21: note: suggested alternative: 'sinh'
42:20: error: 'high' was not declared in this scope
42:20: note: suggested alternative: 'sinh'
47:2: error: expected '}' at end of input
exit status 1
This gives you a value from 0 to 8. The high limit is not included. Since you don't give the random number generator a new seed, it will always produce the same sequence of numbers.
so how do i fix it do i right num=random(0, 10)
Yes. Exactly.
Did you change high in these digitalWrite()s to HIGH?
ok il try
this is the only error that is apering
exit status 1
There's a few errors in the code
  1. The HIGH value used in digitalWrite() should be in all caps, otherwise the compiler will look for a variable named high.
  2. You're missing a closing bracket ( } ) after
else {
      digitalWrite(9, HIGH);
      delay(300);
      digitalWrite(9, LOW);
  1. The quotation marks used in most print() functions ( and ) should be ".
With these changes the code does compile, but I haven't tested it for functionality.
i did wnat you said but i still get one error
46:2: error: expected '}' at end of input
exit status 1
Post the code you have now.
char guess;
int secret_num=random(0, 10);
void setup(){
  pinMode(9, OUTPUT);
void loop(){
  if(Serial.available()>0){    <<<< this needs a mating }
  	guess=guess-48;
    digitalWrite(13,HIGH);
    delay(300);
    digitalWrite(11,HIGH);
    delay(300);
  else{
    digitalWrite(9,HIGH);
    delay(300);
See the note I added in the code
this code should work right
Here is a version that only allows 4 guesses and starts a new game when the game ends. (Hint: If you do a binary search you will always win in 4 moves or fewer.)
int SecretNumber = random(0, 10);
const byte TooHighLEDPin = 13;
const byte TooLowLEDPin = 11;
const byte CorrectLEDPin = 9;
  pinMode(TooHighLEDPin, OUTPUT);
  pinMode(TooLowLEDPin, OUTPUT);
  pinMode(CorrectLEDPin, OUTPUT);
  Serial.println("Instructions: Guess numbers form 0 to 9");
  static int errorCount = 0;
  if (Serial.available() > 0)
    int guess = Serial.read() - '0';
    if (guess > SecretNumber)
      errorCount++;
      digitalWrite(TooHighLEDPin, HIGH);
      delay(300);
      digitalWrite(TooHighLEDPin, LOW);
    else if (guess < SecretNumber)
      errorCount++;
      digitalWrite(TooLowLEDPin, HIGH);
      delay(300);
      digitalWrite(TooLowLEDPin, LOW);
      digitalWrite(CorrectLEDPin, HIGH);
      delay(300);
      digitalWrite(CorrectLEDPin, LOW);
      // Start a new game
      errorCount = 0;
    if (errorCount > 4)
      Serial.println("Too many guesses.  You lose.");
      delay(300);
      // Start a new game
      errorCount = 0;
