I have made a little plan using circuito.io and i would like to know if anybody knows if it would work to change some of the components as circuito.io doesn't quite have the same pieces that i have, but has similar ones that do the same thing. Here is an image of what i am using
and i would like to replace the fingerprint sensor (Fingerprint Scanner - TTL (GT-511C3)) with the fingerprint sensor (AS608 Fingerprint Reader Sensor Module). I would also like to replace the motor in the diagram with this motor. I am sorry if this is a dumb question, but i am very new to Arduino and any help would be very much appreciated
To attract the attention of those that are knowledgeable in you topics, circuit.io and fingerprint sensors, maybe include that in the title of your post ?
Such a plan may be helpful to you but not to anybody else. Learn how to draw your own logic circuit diagrams. Hand drawn will be sufficient if well done. Power connections on top and bottom, signals travel from left (inputs) to right (outputs). Components are represented by rectangualr boxes with type IDs and labelled connections, not images.
