Hi guys,
I need help drawing a schematic for the following components:
Arduino Uno, motor shield, two servos, motor, battery, two sensors
thanks so much
Hi guys,
thanks so much
Why so urgent?
Do you know how to connect them together?
Do you have a CAD program or want to do it by hand on paper.
What experience do you have in electronics, programming, arduino, hardware?
Tom....
TomGeorge:
Why so urgent?
Tom....
It's due tomorrow for a project!
I've got a basic idea but knowing which inputs fit in where would be so beneficial.
On paper or fritzing
general circuit knowledge.
Thanks
bobbya123:
And you were given out this assignment when?
Sorry mate I don't have anywhere near the time required to do that.
What is your electronics, programming, arduino, hardware experience?
What is the course you are doing?
I wouldn't draw it for you, but tell you how to do the basic schematic drawings.
Weren't you taught this?
We encourage people to learn here, rather than just provide a solution to their problem.
Tom....
Would I just have the Arduino with its inputs on a page and then connect the various components to the ports? I just need help knowing which wires go where given all the components im using. (it's actually for Tuesday morn but need to print it out by mon Eve)
Yes.
Try google lol https://www.google.com/search?q=Arduino+Uno,+motor+shield,+two+servos,+motor,+battery,+two+sensors&rlz=1C1ASUT_enUS543US543&source=lnms&tbm=isch&sa=X&ei=CacPVYuUIIfigwSDsYPoAg&ved=0CAgQ_AUoAg&biw=1242&bih=606#tbm=isch&q=Arduino+Uno%2C+motor+shield%2C+two+servos%2C+motor%2C+battery%2C+two+sensors+schematic
it has lots of just that
be80be:
And then hope you're not the one the Prof calls up to explain their answer.....
He can call I'll tell him how to use google too LOL.. The Op can find each part and make his own it's all there.
But I would of started a week ago LOL.
This reminds me of a EE that was doing his finally year project I gave him the whole thing one part at a time hoping he would work on it.. He didn't two days before it was do he emailed for code to make it all work.
I said that was your part didn't you do anything? His reply was I cost him four years of collage I'm thinking dang why didn't I go to collage for four years. I felt bad and gave him the code too guess what LOL he still couldn't tell them how it was done.
JimBo your right can't give it all to them.
Assuming the prof isn't reading this...
bobbya123:
I need help drawing a schematic for the following components:Arduino Uno, motor shield, two servos, motor, battery, two sensors
Your original post is breathtaking in its lack of information. What motor shield? What servos? What motor? What battery? What sensors?
Look, draw a box on the left. Label it "Arduino Uno". Now draw some boxes on the right. Label them appropriately. Draw lines between the ones on the right and the Arduino. Job done, right?
Here's an analogy:
Next time you travel in an aircraft, Jumbo Jet, Airbus, whatever, you kind-of hope, do you not, that the captain knows his or her stuff? You hope that if something goes wrong they actually studied how to handle engine failures, electrical failures, instrument failures, strong winds, hail, lightning and so on, don't you? How confident would you be if you knew that most pilots just cheated to get their licenses and they have no idea of how the damn thing works, except when everything goes perfectly, and all the gadgets work?
You also hope that the captain got more than 50% in his/her landing tests, that they maybe got 99% and were pretty good at their job. And if you hope that other people in your life (I could give other examples, like doctors, dentists, builders) are competent, isn't it up to you to also be competent? So that when you design or build an electronic gadget you actually do a good job?
"A lack of planning on your part, does not constitute a panic on my part."
Weedpharma
As a generality, the term "URGENT!" in a subject line is an invitation to spend at least two days considering the reply.
