I think I might be able to help a bunch of folks with this one in Windows, navigate to C:\Users\YourName\AppData\Local\Temp\arduino_build_227332, and replace the number for the one you see in your folder, after that delete the file includes.cache. Go back to the Arduino IDE and try to compile again and see if it works. Also, there might be a couple of arduino_build_# folders so you might have to find the one which is being used for your current session and if it works you will have to keep deleting this file each time before you recompile, I haven't found away around deleting the file yet.
As I said yours might be numbered differently but inside there is a folder it will contain the current script you are trying to compile, when you locate the folder delete the includes.cache from within the folder and it should compile. I got the same message and nothing turns up with verbose mode on it just dies with ...
Detecting libraries used...
Error compiling for board Arduino Uno.
but in my case, it was a Mega. if that doesn't help you out I'm not sure what it could be but it looks like it might be the same problem.
Hi @orgllk. Does this error occur even when you compile the basic sketch the Arduino IDE creates when you select File > New from the Arduino IDE menus?
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
Start Windows "File Explorer".
Open the Arduino IDE installation folder.
(usually C:\Program Files\Arduino IDE or C:\Users\<username>\AppData\Local\Programs\Arduino IDE).
In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
From the context menu, click "Open PowerShell window here".
Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
Type the following command:
& ".\Arduino IDE"
Press the Enter key.
Debug output should now be printed to the PowerShell window as Arduino IDE starts.
Wait for Arduino IDE to finish starting.
Attempt to upload the sketch to your Uno again, just as you did before.
Wait for the upload process to error.
Switch back to the PowerShell window.
Right click on the title bar of the PowerShell window.
This will open a context menu.
Select Edit > Select All from the context menu.
This will select all the text in the PowerShell window.
Press Ctrl+C.
This will copy the contents of the PowerShell window to the clipboard.
Open a forum reply here by clicking the Reply button.
Click the </> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press Ctrl+V.
This will paste the output into the code block.
Move the cursor outside of the code block markup before you add any additional text to your reply.
Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
