@sana4811 - You should now see that you can not just get any code from the internet, upload it, and expect it to work. You should also see that you can not just combined sketches without knowing how they work, and what you need to remove, change or add. You should learn about the devices you have, the libraries these devices use, and how to put hardware and software together to create a working sketch to upload and function. I put the sketch you posted into a simulator, removed, changed and added what was needed to get it working... which you should have done.
sketch.ino
#include <Wire.h>
#include "ds3231.h" // needs config.h, ds3231.cpp
#define BUFF_MAX 128
// remove this block of commented lines - refers to non-I2C LCD
//---(Following are the PCF8574 pin assignments to LCD connections )----
// This are different than earlier/different I2C LCD displays
// #define Rs_pin 0
// #define Rw_pin 1
// #define En_pin 2
// #define BACKLIGHT_PIN 3
// #define D4_pin 4
// #define D5_pin 5
// #define D6_pin 6
// #define D7_pin 7
// #define LED_OFF 0
// #define LED_ON 1
// ---- -( Declare objects )---- - /
// this says I2C, but is using both I2C and ?other? pin protocol
// LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
//****************************************Define I2C LCD Display *********************************
#define I2C_ADDR 0x27 // Define I2C Address for the PCF8574T
LiquidCrystal_I2C lcd(0x27, 16, 2); // USE THIS FOR I2C LCD
//************************************ END LCD DISPLAY *******************************************
uint8_t time[8]; // (1) redeclaration of "time" (2) never used
char recv[BUFF_MAX];
unsigned int recv_size = 0;
unsigned long prev, interval = 1000;
Wire.begin();
// DS3231_init(DS3231_INTCN); // archaic
DS3231_init(DS3231_CONTROL_INTCN);
memset(recv, 0, BUFF_MAX); // WHY?
Serial.println("GET time");
//LCD Setup******
lcd.begin (16, 2); // initialize the lcd
lcd.backlight(); // this is the correct function call
// Switch on the backlight
// lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE); // not I2C LCD
// lcd.setBacklight(LED_ON); // not I2C LCD
//END LCD Setup*****
Serial.println("Setting time");
setTheTime("304022129022016"); // ssmmhhWDDMMYYYY set time once in the given format
char tempF[6];
float temperature;
char buff[BUFF_MAX];
unsigned long now = millis();
struct ts t;
// show time once in a while
if (now - prev > interval) {
DS3231_get(&t); //Get time
temperature = DS3231_get_treg(); //Get temperature
dtostrf(temperature, 5, 1, tempF);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(t.mday);
printMonth(t.mon);
lcd.print(t.year);
lcd.setCursor(0, 1); //Go to second line of the LCD Screen
lcd.print(t.hour);
lcd.print(":");
if (t.min < 10)
lcd.print("0");
lcd.print(t.min);
lcd.print(":");
if (t.sec < 10)
lcd.print("0");
lcd.print(t.sec);
lcd.print(' ');
lcd.print(tempF);
lcd.print((char)223);
lcd.print("C ");
prev = now;
void setTheTime(char *cmd)
struct ts t;
t.sec = inp2toi(cmd, 0);
t.min = inp2toi(cmd, 2);
t.hour = inp2toi(cmd, 4);
t.wday = inp2toi(cmd, 6);
t.mday = inp2toi(cmd, 7);
t.mon = inp2toi(cmd, 9);
t.year = inp2toi(cmd, 11) * 100 + inp2toi(cmd, 13);
DS3231_set(t);
Serial.println("OK");
void printMonth(int month)
switch (month)
case 1: lcd.print(" January "); break;
case 2: lcd.print(" February "); break;
case 3: lcd.print(" March "); break;
case 4: lcd.print(" April "); break;
case 5: lcd.print(" May "); break;
case 6: lcd.print(" June "); break;
case 7: lcd.print(" July "); break;
case 8: lcd.print(" August "); break;
case 9: lcd.print(" September "); break;
case 10: lcd.print(" October "); break;
case 11: lcd.print(" November "); break;
case 12: lcd.print(" December "); break;
default: lcd.print(" Error "); break;
ds3231.h (note: lower case)
#ifndef __ds3231_h_
#define __ds3231_h_
//#if ARDUINO >= 100
#include <Arduino.h>
//#else
//#include <WProgram.h>
//#endif
#include "config.h"
#define DS3231_TRANSACTION_TIMEOUT 100 // Wire NAK/Busy timeout in ms
#define SECONDS_FROM_1970_TO_2000 946684800
// i2c slave address of the DS3231 chip
#define DS3231_I2C_ADDR 0x68
// timekeeping registers
#define DS3231_TIME_CAL_ADDR 0x00
#define DS3231_ALARM1_ADDR 0x07
#define DS3231_ALARM2_ADDR 0x0B
#define DS3231_CONTROL_ADDR 0x0E
#define DS3231_STATUS_ADDR 0x0F
#define DS3231_AGING_OFFSET_ADDR 0x10
#define DS3231_TEMPERATURE_ADDR 0x11
// control register bits
#define DS3231_CONTROL_A1IE 0x1 /* Alarm 2 Interrupt Enable */
#define DS3231_CONTROL_A2IE 0x2 /* Alarm 2 Interrupt Enable */
#define DS3231_CONTROL_INTCN 0x4 /* Interrupt Control */
#define DS3231_CONTROL_RS1 0x8 /* square-wave rate select 2 */
#define DS3231_CONTROL_RS2 0x10 /* square-wave rate select 2 */
#define DS3231_CONTROL_CONV 0x20 /* Convert Temperature */
#define DS3231_CONTROL_BBSQW 0x40 /* Battery-Backed Square-Wave Enable */
#define DS3231_CONTROL_EOSC 0x80 /* not Enable Oscillator, 0 equal on */
// status register bits
#define DS3231_STATUS_A1F 0x01 /* Alarm 1 Flag */
#define DS3231_STATUS_A2F 0x02 /* Alarm 2 Flag */
#define DS3231_STATUS_BUSY 0x04 /* device is busy executing TCXO */
#define DS3231_STATUS_EN32KHZ 0x08 /* Enable 32KHz Output */
#define DS3231_STATUS_OSF 0x80 /* Oscillator Stop Flag */
struct ts {
uint8_t sec; /* seconds */
uint8_t min; /* minutes */
uint8_t hour; /* hours */
uint8_t mday; /* day of the month */
uint8_t mon; /* month */
int16_t year; /* year */
uint8_t wday; /* day of the week */
uint8_t yday; /* day in the year */
uint8_t isdst; /* daylight saving time */
uint8_t year_s; /* year in short notation*/
#ifdef CONFIG_UNIXTIME
uint32_t unixtime; /* seconds since 01.01.1970 00:00:00 UTC*/
#endif
void DS3231_init(const uint8_t creg);
void DS3231_set(struct ts t);
void DS3231_get(struct ts *t);
void DS3231_set_addr(const uint8_t addr, const uint8_t val);
uint8_t DS3231_get_addr(const uint8_t addr);
// control/status register
void DS3231_set_creg(const uint8_t val);
uint8_t DS3231_get_creg(void);
void DS3231_set_sreg(const uint8_t val);
uint8_t DS3231_get_sreg(void);
// aging offset register
void DS3231_set_aging(const int8_t val);
int8_t DS3231_get_aging(void);
// temperature register
float DS3231_get_treg(void);
void DS3231_set_32kHz_output(const uint8_t on);
// alarms
void DS3231_set_a1(const uint8_t s, const uint8_t mi, const uint8_t h, const uint8_t d,
const uint8_t * flags);
void DS3231_get_a1(char *buf, const uint8_t len);
void DS3231_clear_a1f(void);
uint8_t DS3231_triggered_a1(void);
void DS3231_set_a2(const uint8_t mi, const uint8_t h, const uint8_t d, const uint8_t * flags);
void DS3231_get_a2(char *buf, const uint8_t len);
void DS3231_clear_a2f(void);
uint8_t DS3231_triggered_a2(void);
// helpers
uint32_t get_unixtime(struct ts t);
uint8_t dectobcd(const uint8_t val);
uint8_t bcdtodec(const uint8_t val);
uint8_t inp2toi(char *cmd, const uint16_t seek);
#endif
ds3231.cpp
DS3231 library for the Arduino.
This library implements the following features:
- read/write of current time, both of the alarms,
control/status registers, aging register
- read of the temperature register, and of any address from the chip.
Author: Petre Rodan <petre.rodan@simplex.ro>
Available from: https://github.com/rodan/ds3231
The DS3231 is a low-cost, extremely accurate I2C real-time clock
(RTC) with an integrated temperature-compensated crystal oscillator
(TCXO) and crystal.
GNU GPLv3 license:
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <Wire.h>
#include <stdio.h>
#include "ds3231.h"
#ifdef __AVR__
#include <avr/pgmspace.h>
// Workaround for http://gcc.gnu.org/bugzilla/show_bug.cgi?id=34734
#ifdef PROGMEM
#undef PROGMEM
#define PROGMEM __attribute__((section(".progmem.data")))
#endif
#else
#define PROGMEM
#define xpgm_read_byte(addr) (*(const uint8_t *)(addr))
#endif
/* control register 0Eh/8Eh
bit7 EOSC Enable Oscillator (1 if oscillator must be stopped when on battery)
bit6 BBSQW Battery Backed Square Wave
bit5 CONV Convert temperature (1 forces a conversion NOW)
bit4 RS2 Rate select - frequency of square wave output
bit3 RS1 Rate select
bit2 INTCN Interrupt control (1 for use of the alarms and to disable square wave)
bit1 A2IE Alarm2 interrupt enable (1 to enable)
bit0 A1IE Alarm1 interrupt enable (1 to enable)
void DS3231_init(const uint8_t ctrl_reg)
DS3231_set_creg(ctrl_reg);
DS3231_set_32kHz_output(false);
uint8_t i, century;
if (t.year >= 2000) {
century = 0x80;
t.year_s = t.year - 2000;
century = 0;
t.year_s = t.year - 1900;
uint8_t TimeDate[7] = { t.sec, t.min, t.hour, t.wday, t.mday, t.mon, t.year_s };
Wire.beginTransmission(DS3231_I2C_ADDR);
Wire.write(DS3231_TIME_CAL_ADDR);
for (i = 0; i <= 6; i++) {
TimeDate[i] = dectobcd(TimeDate[i]);
if (i == 5)
TimeDate[5] += century;
Wire.write(TimeDate[i]);
Wire.endTransmission();
uint8_t TimeDate[7]; //second,minute,hour,dow,day,month,year
uint8_t century = 0;
uint8_t i, n;
uint16_t year_full;
uint8_t gotData = false;
uint32_t start = millis(); // start timeout
while (millis() - start < DS3231_TRANSACTION_TIMEOUT) {
if (Wire.requestFrom(DS3231_I2C_ADDR, 7) == 7) {
gotData = true;
delay(2);
if (!gotData)
return; // error timeout
n = Wire.read();
if (i == 5) {
TimeDate[5] = bcdtodec(n & 0x1F);
century = (n & 0x80) >> 7;
} else
TimeDate[i] = bcdtodec(n);
if (century == 1) {
year_full = 2000 + TimeDate[6];
year_full = 1900 + TimeDate[6];
t->sec = TimeDate[0];
t->min = TimeDate[1];
t->hour = TimeDate[2];
t->mday = TimeDate[4];
t->mon = TimeDate[5];
t->year = year_full;
t->wday = TimeDate[3];
t->year_s = TimeDate[6];
t->unixtime = get_unixtime(*t);
#endif
Wire.write(addr);
Wire.write(val);
uint8_t rv;
Wire.write(addr);
if (Wire.requestFrom(DS3231_I2C_ADDR, 1) == 1) {
gotData = true;
delay(2);
if (!gotData)
return 0; // error timeout
rv = Wire.read();
return rv;
// control register
DS3231_set_addr(DS3231_CONTROL_ADDR, val);
uint8_t rv;
rv = DS3231_get_addr(DS3231_CONTROL_ADDR);
return rv;
// status register 0Fh/8Fh
bit7 OSF Oscillator Stop Flag (if 1 then oscillator has stopped and date might be innacurate)
bit3 EN32kHz Enable 32kHz output (1 if needed)
bit2 BSY Busy with TCXO functions
bit1 A2F Alarm 2 Flag - (1 if alarm2 was triggered)
bit0 A1F Alarm 1 Flag - (1 if alarm1 was triggered)
DS3231_set_addr(DS3231_STATUS_ADDR, val);
uint8_t rv;
rv = DS3231_get_addr(DS3231_STATUS_ADDR);
return rv;
// aging register
uint8_t reg;
if (val >= 0)
reg = val;
reg = ~(-val) + 1; // 2C
At 25°C the aging change of:
+1 means -0.1ppm
-1 means -0.1ppm
DS3231_set_addr(DS3231_AGING_OFFSET_ADDR, reg);
A conversion mut be done to forace the new aging value.
DS3231_set_creg(DS3231_get_creg() | DS3231_CONTROL_CONV);
uint8_t reg;
int8_t rv;
reg = DS3231_get_addr(DS3231_AGING_OFFSET_ADDR);
if ((reg & 0x80) != 0)
rv = reg | ~((1 << 8) - 1); // if negative get two's complement
rv = reg;
return rv;
float DS3231_get_treg()
float rv;
uint8_t temp_msb, temp_lsb;
int8_t nint;
Wire.write(DS3231_TEMPERATURE_ADDR);
if (Wire.requestFrom(DS3231_I2C_ADDR, 2) == 2) {
gotData = true;
delay(2);
if (!gotData)
temp_msb = Wire.read();
temp_lsb = Wire.read() >> 6;
if ((temp_msb & 0x80) != 0)
nint = temp_msb | ~((1 << 8) - 1); // if negative get two's complement
nint = temp_msb;
rv = 0.25 * temp_lsb + nint;
return rv;
Note, the pin1 is an open drain pin, therfore a pullup
resitor is required to use the output.
if (on) {
uint8_t sreg = DS3231_get_sreg();
sreg &= ~DS3231_STATUS_OSF;
sreg |= DS3231_STATUS_EN32KHZ;
DS3231_set_sreg(sreg);
sreg &= ~DS3231_STATUS_EN32KHZ;
// alarms
// flags are: A1M1 (seconds), A1M2 (minutes), A1M3 (hour),
// A1M4 (day) 0 to enable, 1 to disable, DY/DT (dayofweek == 1/dayofmonth == 0)
void DS3231_set_a1(const uint8_t s, const uint8_t mi, const uint8_t h, const uint8_t d, const uint8_t * flags)
uint8_t t[4] = { s, mi, h, d };
uint8_t i;
Wire.write(DS3231_ALARM1_ADDR);
for (i = 0; i <= 3; i++) {
if (i == 3) {
Wire.write(dectobcd(t[3]) | (flags[3] << 7) | (flags[4] << 6));
} else
Wire.write(dectobcd(t[i]) | (flags[i] << 7));
uint8_t n[4];
uint8_t t[4]; //second,minute,hour,day
uint8_t f[5]; // flags
uint8_t i;
if (Wire.requestFrom(DS3231_I2C_ADDR, 4) == 4) {
gotData = true;
delay(2);
if (!gotData)
n[i] = Wire.read();
f[i] = (n[i] & 0x80) >> 7;
t[i] = bcdtodec(n[i] & 0x7F);
f[4] = (n[3] & 0x40) >> 6;
t[3] = bcdtodec(n[3] & 0x3F);
snprintf(buf, len,
"s%02d m%02d h%02d d%02d fs%d m%d h%d d%d wm%d %d %d %d %d",
t[0], t[1], t[2], t[3], f[0], f[1], f[2], f[3], f[4], n[0],
n[1], n[2], n[3]);
// when the alarm flag is cleared the pulldown on INT is also released
uint8_t reg_val;
reg_val = DS3231_get_sreg() & ~DS3231_STATUS_A1F;
DS3231_set_sreg(reg_val);
return DS3231_get_sreg() & DS3231_STATUS_A1F;
// flags are: A2M2 (minutes), A2M3 (hour), A2M4 (day) 0 to enable, 1 to disable, DY/DT (dayofweek == 1/dayofmonth == 0) -
uint8_t t[3] = { mi, h, d };
uint8_t i;
Wire.write(DS3231_ALARM2_ADDR);
for (i = 0; i <= 2; i++) {
if (i == 2) {
Wire.write(dectobcd(t[2]) | (flags[2] << 7) | (flags[3] << 6));
} else
uint8_t n[3];
uint8_t t[3]; //second,minute,hour,day
uint8_t f[4]; // flags
uint8_t i;
Wire.requestFrom(DS3231_I2C_ADDR, 4);
if (Wire.requestFrom(DS3231_I2C_ADDR, 3) == 3) {
gotData = true;
delay(2);
if (!gotData)
n[i] = Wire.read();
f[3] = (n[2] & 0x40) >> 6;
t[2] = bcdtodec(n[2] & 0x3F);
snprintf(buf, len, "m%02d h%02d d%02d fm%d h%d d%d wm%d %d %d %d", t[0],
t[1], t[2], f[0], f[1], f[2], f[3], n[0], n[1], n[2]);
uint8_t reg_val;
reg_val = DS3231_get_sreg() & ~DS3231_STATUS_A2F;
return DS3231_get_sreg() & DS3231_STATUS_A2F;
// helpers
const uint8_t days_in_month [12] PROGMEM = { 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 };
// returns the number of seconds since 01.01.1970 00:00:00 UTC, valid for 2000..FIXME
uint8_t i;
uint16_t d;
int16_t y;
uint32_t rv;
y = t.year - 2000;
return 0;
d = t.mday - 1;
for (i = 1; i < t.mon; i++) {
d += xpgm_read_byte(days_in_month + i - 1);
if (t.mon > 2 && y % 4 == 0) {
d++;
// count leap days
d += (365 * y + (y + 3) / 4);
rv = ((d * 24UL + t.hour) * 60 + t.min) * 60 + t.sec + SECONDS_FROM_1970_TO_2000;
return rv;
#endif
return ((val / 10 * 16) + (val % 10));
return ((val / 16 * 10) + (val % 16));
uint8_t rv;
rv = (cmd[seek] - 48) * 10 + cmd[seek + 1] - 48;
return rv;
config.h
#ifndef __config_h_
#define __config_h_
#if defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_ARCH_SAMD) || defined(ARDUINO_ARCH_ESP32)
// on the the D21 and ESP32 the C-Runtime uses already UNIX time
#define CONFIG_UNIXTIME
#else
// comment this out if you need unixtime support
// this will add about 324bytes to your firmware
//#define CONFIG_UNIXTIME
#endif
#endif
