I have a custom PCBA (nano shield) with the MPU-6050 accelerometer. The schematic is shown below.
I am able to see the device on i2c, but am not able to communicate with the device whatever library I use.
I'm aware that VCC should be at 3.3V, which I have corrected manually (on a fresh unused MPU6050).
I've also tried pulling AD0 high (3.3V) to no avail.
I'm not sure why it isn't working. Perhaps AUX_DA or AUX_CL need to be connected? I haven't been able to discern what to do with these pins since I'm not utilising them for peripheral i2C devices.
I'm using a standard Arduino Nano, and not the Every.
Almost all sensors these days are 3.3V, but hobby suppliers like Sparkfun, Adafruit and Pololu add logic level converters to their breakout modules, so that they function with either 5V or 3.3V logic.
An excellent replacement for the MPU-6050 is the ISM330DHCX, with vastly improved performance.
5V logic will soon be a thing of the past, and modern 3.3V Arduino MCU boards are faster, more powerful and have lots more memory, so there are many good reasons to migrate to 3.3V only systems.
Thank you for all the information, there is always much to learn!
I also found a solution. Leaving the MPU6050 running at 5V VCC and then pulling up the AD0 worked. Since I left AD0 floating the address was ambigous and caused issues.
I'll look into 3.3V alternatives for future projects.
