Cannot compile for esp32 boards
Good Morning,
Im currently trying to compile an empty sketch (just clicked the "new sketch" button) for a esp32 board (wemos d1 mini esp32).
I downloaded/installed the esp32 boards and selected wemos d1 mini esp32 and got the following error when compiling (not uploading, just compiling)
Traceback (most recent call last):
  File "esptool.py", line 57, in <module>
  File "/Library/Python/2.7/site-packages/PyInstaller/loader/pyimod03_importers.py", line 389, in load_module
  File "serial/tools/list_ports.py", line 29, in <module>
  File "serial/tools/list_ports_posix.py", line 31, in <module>
  File "serial/tools/list_ports_osx.py", line 32, in <module>
ValueError: dlsym(RTLD_DEFAULT, kIOMasterPortDefault): symbol not found
Failed to execute script esptool
exit status 255
/Applications/Arduino.app/Contents/Java/arduino-builder gab 255 zurück
Fehler beim Kompilieren für das Board WEMOS D1 MINI ESP32.
this also occurs if i select ANY other esp32 board as build target...
what might cause this?
Welcome to the forum.
Please read http://forum.arduino.cc/index.php/topic,148850.0.html.
What version IDE and what OS are you using?
Tom... :slight_smile:
When the ESP is not plugged into the USB select, in the Arduino IDE, Tool|Port,, and write down the port numbers.
When the ESP is plugged into the USB select, in the Arduino IDE, Tool|Port,, and write down the port numbers.
Compare the port number lists, do they match or is their more ports available when the ESP is plugged in?
I ran this code and it compiled, IDE 1.8.13 with Win12.
wemos d1 mini esp32 selected.
Did you put this in the preferences box?
https://dl.espressif.com/dl/package_esp32_index.json
