cannot figure out error im getting from marlin 2.0 firmware
im trying to update my cr 10 with the new marlin 2.0 I believe but cannot figure this error out for the life of me. I only know what ive learned over youtube for the last year so I understand very little but enough to be walked through pretty easily. if someone can help id really apreaciate it. I promise thjis was my last resort after wasting 3 days of on/off browsing for answers.
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp: In function 'int lcd_put_wchar_max(uint32_t, pixel_len_t)':
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:36:22: error: 'class U8GLIB_ST7920_128X64_RRD' has no member named 'getPrintCol'; did you mean 'setPrintPos'?
u8g_uint_t x = u8g.getPrintCol(), y = u8g.getPrintRow(),
setPrintPos
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:38:23: error: 'ret' was not declared in this scope
u8g.setPrintPos(x + ret, y);
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:38:23: note: suggested alternative: 'reti'
reti
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:38:28: error: 'y' was not declared in this scope
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp: In function 'int lcd_put_u8str_max(const char*, pixel_len_t)':
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:43:22: error: 'class U8GLIB_ST7920_128X64_RRD' has no member named 'getPrintCol'; did you mean 'setPrintPos'?
setPrintPos
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:45:23: error: 'ret' was not declared in this scope
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:45:23: note: suggested alternative: 'reti'
reti
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:45:28: error: 'y' was not declared in this scope
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp: In function 'int lcd_put_u8str_max_P(const char*, pixel_len_t)':
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:50:22: error: 'class U8GLIB_ST7920_128X64_RRD' has no member named 'getPrintCol'; did you mean 'setPrintPos'?
setPrintPos
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:52:23: error: 'ret' was not declared in this scope
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:52:23: note: suggested alternative: 'reti'
reti
C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\lcdprint_u8g.cpp:52:28: error: 'y' was not declared in this scope
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\Documents\Arduino\Hardware\Lauszus-Sanguino-4aa3893\avr\variants\sanguino" "-IC:\Users\USER\Documents\Arduino\libraries\U8glib" "C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\u8g_dev_st7920_128x64_HAL.cpp" -o "C:\Users\USER\AppData\Local\Temp\arduino_build_343907\sketch\src\lcd\dogm\u8g_dev_st7920_128x64_HAL.cpp.o"
Multiple libraries were found for "U8glib.h"
Used: C:\Users\USER\Documents\Arduino\libraries\U8glib
Using library U8glib in folder: C:\Users\USER\Documents\Arduino\libraries\U8glib (legacy)
exit status 1
Error compiling for board Sanguino.
ive tried to find the multiple u8glib libraries in my docs, Arduino, libraries but there was no duplicates. idk what im looking for so any answers are appreaciated.
I recently picked up a used 3d printer with a damaged controller board. So I bought a ramps board and installed marlin 2.0 on it. I mention this because I've never installed U8glib on my pc and marlin did not require me to install it or any other libraries..
This leads me to believe that marlin has a version of U8glib built in and maybe all you need to do is remove the U8glib from your libraries file so that it can install the proper one that is included with marlin.
This is just a guess I really don't know if this is the case here. You will likely find better answers on a 3d printing site where there are more people who are familiar with the marlin software.
