Cannot manage to wire up a transistor :@
So I followed this diagram and I have no idea why it's not working...
 3V --+--------+
      /      __|__   .
      \ 1k   \   /  /.  blue
      /      _\_/_  /   LED
      |        | collector
          base |\  emitter
I know it's hard to see in the photo but I followed the diagram exactly. The only thing in not 100% sure of is whether the the emitter goes tk ground (which is where I put it). This is so frustrating. I have tried to put transistors in a circuit so many times and it never works, why!!?
What is Vf for the LED?
What's the transistor? it might be a PNP which would account for this issue.
But with 3v, take a 100-300 ohm resistor and find out if the LED is even working!
cjdelphi:
Yes the LED is working and the transistor is a PNP (S8550), so it is the right way, I looked at the data sheet. But I have tried it the opposite way and it still doesnt work.
Noahsdev:
  • no you didn't : I see 2 resistors in you wiring :wink:
  • I'm not sure of the colours from your photo, could you tell us the resistors values ?
  • last, but not least .... if it is a pnp, it will never work if you follow this diagram : for a PNP to switch on, its base must be at least 0,6V less than emitter voltage !!
edit : look at this page SECARS Homepage - SECARS
Noahsdev:
cjdelphi:
By the looks of it, youhave the base pin hooked up to the positive voltage rail (NPN's do this) PNP needs to be connected to gnd/0v.
PNP and NPN are wired up completely differently.
The way you have the circuit wired up is correct for an NPN transistor, but not for a PNP transistor.
