Hi all, I just got some NPN transistors for a project I’m working on and I think I’m probably using them wrong. Basically what I want is for the arduino to switch the transistor that is connected to 12v to power several LEDs. I’ve found countless tutorials and guides and I’m pretty sure I’m hooking it up right (but probably not).
Basically what’s happening is if the base is LOW (or even if nothing is connected there) then the LED that I have connected is still about half lit. If I pull the base HIGH though it gets to full brightness. What am I doing wrong? If the base is LOW (or not connected to anything) then the LED should not be lit at all, correct?
The setup I have is similar to the photographed, handwritten schematic on this page: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1240103773
The only difference is my voltage and resistor values and a resistor between the arduino output and base. I’m new to transistors and I’m sure this is a noob mistake. Thanks in advance.
