Getting this error message when I click on serial monitor to open it.
I am using an arduino uno and the web editor.
Any ideas what this error means?
I think it must be on my code. Other same hello world serial print simple programs work with the same arduino cable and hardware.
Here is the code I am trying to run.
/* -- New project --
This source code of graphical user interface has been generated automatically by RemoteXY editor.
To compile this code using RemoteXY library 3.1.13 or later version download by link http://remotexy.com/en/library/
To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
- for ANDROID 4.15.01 or later version;
- for iOS 1.12.1 or later version;
This source code is free software; you can redistribute it and/or modify
it under the terms of the GNU Lesser General Public License as published by
the Free Software Foundation; either version 2.1 of the License, or
(at your option) any later version.
// RemoteXY include library
// you can enable debug logging to Serial at 115200
//#define REMOTEXY__DEBUGLOG
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__SOFTSERIAL
#include <SoftwareSerial.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL_RX 2
#define REMOTEXY_SERIAL_TX 3
#define REMOTEXY_SERIAL_SPEED 9600
#include <RemoteXY.h>
// RemoteXY GUI configuration
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] = // 73 bytes
{ 255,7,0,0,0,66,0,19,0,0,0,0,31,1,200,84,1,1,6,0,
5,5,5,72,72,32,2,26,31,4,85,6,24,72,0,2,26,1,118,14,
24,24,0,2,31,0,1,155,3,24,24,0,2,31,0,1,135,54,24,24,
0,2,31,0,1,170,39,24,24,0,2,31,0 };
// this structure defines all the variables and events of your control interface
struct {
// input variables
int8_t joystick_01_x; // from -100 to 100
int8_t joystick_01_y; // from -100 to 100
int8_t slider_01; // from 0 to 100
uint8_t button_01; // =1 if button pressed, else =0
uint8_t button_02; // =1 if button pressed, else =0
uint8_t button_03; // =1 if button pressed, else =0
uint8_t button_04; // =1 if button pressed, else =0
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include
// Variables to store previous values for change detection
int8_t prev_joystick_01_x = 0;
int8_t prev_joystick_01_y = 0;
int8_t prev_slider_01 = 0;
uint8_t prev_button_01 = 0;
uint8_t prev_button_02 = 0;
uint8_t prev_button_03 = 0;
uint8_t prev_button_04 = 0;
uint8_t prev_connect_flag = 0;
RemoteXY_Init();
// Initialize Serial communication for printing variables
RemoteXY_Handler();
// Print variables when they change or if connection status changes
printVariablesIfChanged();
// Use RemoteXY_delay() instead of delay()
void printVariablesIfChanged() {
// Check if connection status changed
if (prev_connect_flag != RemoteXY.connect_flag) {
prev_connect_flag = RemoteXY.connect_flag;
if (RemoteXY.connect_flag) {
Serial.println("Connected to RemoteXY app");
Serial.println("Disconnected from RemoteXY app");
// Only print when connected and values change
// Check joystick X
if (prev_joystick_01_x != RemoteXY.joystick_01_x) {
prev_joystick_01_x = RemoteXY.joystick_01_x;
Serial.print("Joystick X: ");
Serial.println(RemoteXY.joystick_01_x);
// Check joystick Y
if (prev_joystick_01_y != RemoteXY.joystick_01_y) {
prev_joystick_01_y = RemoteXY.joystick_01_y;
Serial.print("Joystick Y: ");
Serial.println(RemoteXY.joystick_01_y);
// Check slider
if (prev_slider_01 != RemoteXY.slider_01) {
prev_slider_01 = RemoteXY.slider_01;
Serial.print("Slider: ");
Serial.println(RemoteXY.slider_01);
// Check button 1
if (prev_button_01 != RemoteXY.button_01) {
prev_button_01 = RemoteXY.button_01;
Serial.print("Button 1: ");
Serial.println(RemoteXY.button_01 ? "PRESSED" : "RELEASED");
// Check button 2
if (prev_button_02 != RemoteXY.button_02) {
prev_button_02 = RemoteXY.button_02;
Serial.print("Button 2: ");
Serial.println(RemoteXY.button_02 ? "PRESSED" : "RELEASED");
// Check button 3
if (prev_button_03 != RemoteXY.button_03) {
prev_button_03 = RemoteXY.button_03;
Serial.print("Button 3: ");
Serial.println(RemoteXY.button_03 ? "PRESSED" : "RELEASED");
// Check button 4
if (prev_button_04 != RemoteXY.button_04) {
prev_button_04 = RemoteXY.button_04;
Serial.print("Button 4: ");
Serial.println(RemoteXY.button_04 ? "PRESSED" : "RELEASED");
Hi, this has also happened to me before. I just waited around 15 seconds and pressed it again. Also, are you using the built in serial port or a library? I am asking because I see #include <SoftwareSerial.h> in your program and I only have experience with the built in serial (that being Serial.print("your text here"); to send and Serial.begin(9600); to start it)
Have a great day!
