I'm a long time Arduino user and I'm just looking at using the Arduino Cloud Dashboard. So I'm using the Cloud IDE. I added a new device (MKR1010) successfully, have the Agent installed, created a very simple dashboard (doesn't really matter this this point), created a Thing (also doesn't really matter), and tried to upload the sketch that the system built for me.
When I try to upload, I get the following error:
/usr/local/bin/arduino-cli compile --fqbn arduino:samd:mkrwifi1010 --build-cache-path /tmp --output-dir /tmp/3107547542/build --build-path /tmp/arduino-build-A6F203315198F94007151A4E655709D4 --library /mnt/create-efs/webide/96/ab/96abf2e47368fe4b461dc70b0f4ddb93:IraSch/libraries_v2/ILI9488 --library /mnt/create-efs/webide/96/ab/96abf2e47368fe4b461dc70b0f4ddb93:IraSch/libraries_v2/Nick-Gammon-RS485 --library /mnt/create-efs/webide/96/ab/96abf2e47368fe4b461dc70b0f4ddb93:IraSch/libraries_v2/RAK14014-FT6336U /tmp/3107547542/Alarm_Panel_nov09a
[info] Sketch uses 97304 bytes (37%) of program storage space. Maximum is 262144 bytes.
[info] Global variables use 5468 bytes (16%) of dynamic memory, leaving 27300 bytes for local variables. Maximum is 32768 bytes.
Restarting in bootloader mode
Flashing with command:C:/Users/Ira/.arduino-create/arduino/bossac/1.7.0-arduino3/bossac.exe -i -d --port=COM3 -U true -i -e -w -v C:/Users/Ira/AppData/Local/Temp/arduino-create-agent1434148940/Alarm_Panel_nov09a.bin -R
Set binary mode
No device found on COM3
Send auto-baud
Set binary mode
Executing command: exit status 1
It looks like the issue is that the Agent/IDE is looking for the MKR1010 on COM3, but it is really on COM8 (verified using my standalone IDE that I normally use. Note that I'm not trying to use the standalone IDE at the same time - I just fired it up after I got the above error to verify which COM port the MKR1010 was on.
Is there a way to tell the Cloud IDE or Agent where the device is?
I uninstalled and reinstalled the Agent just in case. The Cloud IDE says the MKR1010 is offline.
THanks.
