Cannot upload to Arduino Uno any more
Hi all. I was doing some programming when suddenly I couldn't upload anymore to my Arduino Uno board from Ubuntu 10.04. My board is connected with the computer and mounted at /dev/ttyACM0. When I'm trying to upload, I get the following error:
processing.app.SerialException: Error opening serial port '/dev/ttyACM0'.
	at processing.app.Serial.<init>(Serial.java:146)
	at processing.app.Serial.<init>(Serial.java:91)
	at processing.app.SerialMonitor.openSerialPort(SerialMonitor.java:204)
	at processing.app.Editor.handleSerial(Editor.java:2415)
	at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:352)
	at java.awt.Component.processMouseEvent(Component.java:6285)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
	at java.awt.Component.processEvent(Component.java:6053)
	at java.awt.Container.processEvent(Container.java:2041)
	at java.awt.Component.dispatchEventImpl(Component.java:4651)
	at java.awt.Container.dispatchEventImpl(Container.java:2099)
	at java.awt.Component.dispatchEvent(Component.java:4481)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4235)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
	at java.awt.Container.dispatchEventImpl(Container.java:2085)
	at java.awt.Window.dispatchEventImpl(Window.java:2478)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:643)
	at java.awt.EventQueue.access$000(EventQueue.java:84)
	at java.awt.EventQueue$1.run(EventQueue.java:602)
	at java.awt.EventQueue$1.run(EventQueue.java:600)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:98)
	at java.awt.EventQueue$2.run(EventQueue.java:616)
	at java.awt.EventQueue$2.run(EventQueue.java:614)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:613)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: gnu.io.UnsupportedCommOperationException: Invalid Parameter
	at gnu.io.RXTXPort.setSerialPortParams(RXTXPort.java:171)
	at processing.app.Serial.<init>(Serial.java:136)
	... 35 more
When I try to run the arduino software as root (sudo arduino), everything works fine!!! However, I am in the dialout group. Any suggestions???
What is the output of
ls -l /dev/ttyACM0
(that's a minus el)
The fourth column (after "root") will be the group that it is in. I'm guessing it's not "dialout"
What version of the IDE are you running?
I found out the solution after a long time of researching. I apologize for double-posting. The answer is more or less found here. The difference is that I couldn't change the contents of the file ~/.arduino/preferences.txt because the arduino software would modidy the value of the parameter serial.debug_rate back to 14400 whenever I was trying to set it to 9600. I finally deleted the folder ~/.arduino and everything now goes like clockwork.
WizenedEE:
ls -l /dev/ttyACM0
(that's a minus el)
BTW, The output is:
crw-rw---- 1 root dialout 166, 0 2012-03-06 04:34 /dev/ttyACM0
After all it was not permissions issue. I had previously set the debug_rate at 14400 and things went wrong from that moment on...
Thanks for that huge hint. I had the same symptom, IDE would only download if user was root. If logged on as normal user I got:
Binary sketch size: 2,464 bytes (of a 30,720 byte maximum)
processing.app.SerialException: Error opening serial port '/dev/ttyUSB1'.
	at processing.app.Serial.<init>(Serial.java:178)
	at processing.app.Serial.<init>(Serial.java:77)
	at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
	at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:172)
	at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
	at processing.app.Sketch.upload(Sketch.java:1706)
	at processing.app.Sketch.exportApplet(Sketch.java:1662)
	at processing.app.Sketch.exportApplet(Sketch.java:1634)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2346)
	at java.lang.Thread.run(Thread.java:636)
	at processing.app.Serial.<init>(Serial.java:163)
	... 9 more
processing.app.debug.RunnerException: Error opening serial port '/dev/ttyUSB1'.
	at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:101)
Deleting the user .arduino eliminated the Java exception but there was an avrdude problem. I solved the issue by copying .arduino/preferences.txt from root to the user .arduino directory.
