Cannot Upload To Nano Every
Can you show what you see in Device Manager under Ports(COM&LPT)?
What do you see if you double click on what shows up as the connected device?
EDIT:
What procedure did you follow to change the COM Port from 1?
This is what it should like, with the computer recognizing a Nano Every on the port. Mine is on 9.
COMPort_Capture
If you go into Device Manager,double click on the "Comunications Port (COM1)"
  1. What do you see for "Driver" and "Driver Details"
    This is what is working for me with a NanoEvery and Win 10
Another idea would be to change the Com Port from 1 to something else, but I'm not sure it will help if there is a usb driver issue.
  1. Under Port Settings "Advanced" you can change the Port from 1 to something else. Maybe that will help.
What have you done to verify that the usb cable is full data, and working properly?
The error message in your first posting is a little jumbled. Can you please compile and try to load the Blink example sketch with File>Preferences and then with show verbose output during compile and upload checked.
Please copy what you see using the code tags.
I even tried a new R4 Minima I jut got, with a cable I've been using for months now to upload sketches. So basically no Arduino works... I'm going to try and do it on another PC and see what happens. But would plugging it into another port do anything?
EDIT
I just tried two other Minima boards, and they worked.
Do you have any idea why some work and others don't? and how I can fix it?
Thank you so much
Trying another PC is the right thing to do to see if the problem is with the board or the Windows installation.
You can certainly try a new slot, or even changing the Nano Every's COM port from 1 to something else, but I would expect that there will be the same lack of recognition on the new port.
You are not helping the trouble shooting process by switching boards and ide versions. Many users are successfully working with a Nano Every, IDE 1.8.19 and Windows 10. Something is broken in your environment, nothing you have said so far would lead me to think is the Nano Every and not Windows.
As suggested on Post #13 by @runaway_pancake have you restarted the PC?
You can also try reloading the ide and the megaavr board package. The last thread I was involved with relating to Windows10 and the Nano Every was an unknow issue with Windows and the usb drivers.
I feel like the question is now different, I no longer need the Nano to work, because at the moment I just need to finish a project soon, and I found that the Uno is better suited for the project I am making, so should I create a new post rather than continuing it here? And yes, last night I shut it off and turned it on in the morning. It cause the PC to recognize it for one upload. But went back to ignoring it.
Should I ask the new question in somewhere like Software>IDE 2.x?
What is the new question?
Indeed you may want to start a new thread and reference this one.
But it sounds like problems with the R4 may indeed be the same issue with the Windows 10 configuration on your PC. Still a new thread with a link back to this one sounds appropriate to me.
You said something about PC config? Are there any changes I could try?
Very Interesting.
Go back and review the postings #22-25. When you use the NanoEvery and you turn the computer off and then back on and it works for the first time, are the drivers showing differently from when it isn't recognized?
@ace595 has created a dedicated topic for discussion of the problem uploading to the UNO R4 Minima board:
Please use that topic for any discussion related to the UNO R4 Minima, and this topic for any discussion related to the Nano Every.
