I have a brand new R4 Minima which is recognized by the computer at COM 8, but when I upload my sketch, it gives me this error, I'm using the IDE 2.3.2
Sketch uses 41784 bytes (15%) of program storage space. Maximum is 262144 bytes.
Global variables use 4352 bytes (13%) of dynamic memory, leaving 28416 bytes for local variables. Maximum is 32768 bytes.
dfu-util 0.11-arduino4
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
Device ID 2341:0069
Run-Time device DFU version 0101
Claiming USB DFU (Run-Time) Interface...
Setting Alternate Interface zero...
Determining device status...
Failed to retrieve language identifiers
error get_status: LIBUSB_ERROR_TIMEOUT
Failed uploading: uploading error: exit status 74
When the sketch program currently running (not the program you are attempting to upload) on the Arduino board produces a high volume of serial output, it causes uploads to fail with this "error get_status: LIBUSB_ERROR_TIMEOUT" error message.
During the upload process, a special signal is sent to the Arduino board which tells it to go into the mode where it can accept the upload. The flood of serial data blocks the receipt of that signal. The workaround is to manually put the board into that mode before the upload.
I'll provide instructions you can follow to do that:
Press and release the button marked "RESET" or "RST" on your board quickly twice.
The built-in LED on the board should start pulsing. ⓘ The double reset puts the board into the update mode. It will stay in this mode until the board is reset normally, powered off, or an upload is done.
Select Sketch > Upload from the Arduino IDE menus.
An "Upload" operation will start.
Wait for the upload to finish successfully.
After that, if you find that the upload continues to fail with the "error get_status: LIBUSB_ERROR_TIMEOUT" error message when you later try to upload normally without performing the double reset procedure, this indicates that the sketch you uploaded is still producing an excessive volume of serial output. You can verify this by uploading a simple sketch like the one from File > Examples > 01.Basics > BareMinimum in the Arduino IDE menus. If the uploads work normally after uploading that sketch, but not after uploading the previous sketch you were using, then you will know the issue is caused by that other sketch code. If it is not intended that the sketch would produce a high volume of serial output and you don't know what is causing this, you can post your sketch code in a reply here on this forum thread to get assistance from the forum helpers with the problem.
