Cannot uploade own sketch to Nano ESP32
EDIT: I tried attaching a .zipped fil containing me sourcecode, but I'm not allowed to upload/attach a file, because I'm considered a "New user".
I also tried to upload in a reply to this post with the same result.
I then don't know how to share it.
I recently bought severeal Nano ESP32 boards for an upcoming project.
I'm able to upload both simple examples e.g. Blink, but also more complex examples e.g. AdvancesWebServer and it is working fine.
I'm also able to upload and execute other of my own project sketches.
I'm using Arduino IDE 2.3.6 and Windows 11.
When I upload my own, the Output says everything is OK and Done.
But the device keeps executing the old prevoiusloy uploaded sketch.
Its difficult for me to upload my sketch source, because it is divided into 7 files.
It used to compile to an ordinary Nano, but I reached the Memory limit and had to switch to another board. Since I already created 3D prints of enclosure suited for PCB's for the Nano layout, it was obvious to start using the Nano ESP32 with benefits in form of more memory, wifi etc. etc.
I have verbose compile options and default warnings. I have a single warning regarding type conversion - but I'm ignoring that for now.
I have had severel issues with the new Nano ESP32 board and have had to erase flash , install new bootloader etc. several times.
I also tried to upload to a brand new board, since I bought several. Same result.
The board has also startet switching port during compile/upload.
Recently I also started getting the "No FDU capable USB device available".
I'm considering going for another type of ESP32.
I'm about to give up. Please help :slight_smile:
Thx in advance.
NB! Output posted in this post and a reply to this post, due to more than 120.000 bytes.
Output:
FQBN: arduino:esp32:nano_nora
Using board 'nano_nora' from platform in folder: C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5
Using core 'esp32' from platform in folder: C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5
cmd /c if exist "K:\\9990 - Arduino\\000 - CODE\\0000 - Project Shade Roller\\0000 - Arduino\\0100 - RollerShadeController\\RollerShadeController\\partitions.csv" COPY /y "K:\\9990 - Arduino\\000 - CODE\\0000 - Project Shade Roller\\0000 - Arduino\\0100 - RollerShadeController\\RollerShadeController\\partitions.csv" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\partitions.csv"
cmd /c if not exist "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\partitions.csv" if exist "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora\\partitions.csv" COPY "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora\\partitions.csv" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\partitions.csv"
cmd /c if not exist "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\partitions.csv" COPY "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\tools\\partitions\\app3M_fat9M_fact512k_16MB.csv" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\partitions.csv"
cmd /c IF EXIST "K:\\9990 - Arduino\\000 - CODE\\0000 - Project Shade Roller\\0000 - Arduino\\0100 - RollerShadeController\\RollerShadeController\\bootloader.bin" ( COPY /y "K:\\9990 - Arduino\\000 - CODE\\0000 - Project Shade Roller\\0000 - Arduino\\0100 - RollerShadeController\\RollerShadeController\\bootloader.bin" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\RollerShadeController.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora\\bootloader.bin" ( COPY "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora\\bootloader.bin" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\RollerShadeController.ino.bootloader.bin" ) ELSE ( "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1\\esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 16MB -o "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\RollerShadeController.ino.bootloader.bin" "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\tools\\sdk\\esp32s3\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32s3 image...
Merged 1 ELF section
Successfully created esp32s3 image.
cmd /c if exist "K:\\9990 - Arduino\\000 - CODE\\0000 - Project Shade Roller\\0000 - Arduino\\0100 - RollerShadeController\\RollerShadeController\\build_opt.h" COPY /y "K:\\9990 - Arduino\\000 - CODE\\0000 - Project Shade Roller\\0000 - Arduino\\0100 - RollerShadeController\\RollerShadeController\\build_opt.h" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\build_opt.h"
cmd /c if not exist "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\build_opt.h" type nul > "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\build_opt.h"
cmd /c type nul > "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/file_opts"
Detecting libraries used...
C:\Users\micro\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/build_opt.h @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/file_opts -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\sketch\RollerShadeController.ino.cpp -o nul
Alternatives for Preferences.h: [Preferences@2.0.0]
ResolveLibrary(Preferences.h)
  -> candidates: [Preferences@2.0.0]
C:\Users\micro\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/build_opt.h @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/file_opts -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences\src C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\sketch\RollerShadeController.ino.cpp -o nul
Alternatives for Encoder.h: [Encoder@1.4.4]
ResolveLibrary(Encoder.h)
  -> candidates: [Encoder@1.4.4]
C:\Users\micro\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/build_opt.h @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/file_opts -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences\src -Ik:\9990 - Arduino\000 - CODE\libraries\Encoder C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\sketch\RollerShadeController.ino.cpp -o nul
Alternatives for OneButton.h: [OneButton@2.6.1]
ResolveLibrary(OneButton.h)
  -> candidates: [OneButton@2.6.1]
C:\Users\micro\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/build_opt.h @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/file_opts -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences\src -Ik:\9990 - Arduino\000 - CODE\libraries\Encoder -Ik:\9990 - Arduino\000 - CODE\libraries\OneButton\src C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\sketch\RollerShadeController.ino.cpp -o nul
Alternatives for LedController.h: [LedController]
ResolveLibrary(LedController.h)
  -> candidates: [LedController]
C:\Users\micro\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/build_opt.h @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/file_opts -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences\src -Ik:\9990 - Arduino\000 - CODE\libraries\Encoder -Ik:\9990 - Arduino\000 - CODE\libraries\OneButton\src -Ik:\9990 - Arduino\000 - CODE\libraries\LedController C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\sketch\RollerShadeController.ino.cpp -o nul
Alternatives for uTimerLib.h: [uTimerLib@1.7.5]
ResolveLibrary(uTimerLib.h)
  -> candidates: [uTimerLib@1.7.5]
C:\Users\micro\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/build_opt.h @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/file_opts -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences\src -Ik:\9990 - Arduino\000 - CODE\libraries\Encoder -Ik:\9990 - Arduino\000 - CODE\libraries\OneButton\src -Ik:\9990 - Arduino\000 - CODE\libraries\LedController -Ik:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\sketch\RollerShadeController.ino.cpp -o nul
Alternatives for RunningAverage.h: [RunningAverage@0.4.8]
ResolveLibrary(RunningAverage.h)
  -> candidates: [RunningAverage@0.4.8]
C:\Users\micro\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/build_opt.h @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/file_opts -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences\src -Ik:\9990 - Arduino\000 - CODE\libraries\Encoder -Ik:\9990 - Arduino\000 - CODE\libraries\OneButton\src -Ik:\9990 - Arduino\000 - CODE\libraries\LedController -Ik:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src -Ik:\9990 - Arduino\000 - CODE\libraries\RunningAverage C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\sketch\RollerShadeController.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences\src\Preferences.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\Encoder\Encoder.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\OneButton\src\OneButton.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\OneButton\src\OneButtonTiny.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\LedController\LedController.cpp
Alternatives for PwmCompat.h: [PwmCompat]
ResolveLibrary(PwmCompat.h)
  -> candidates: [PwmCompat]
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.ATTINY.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.AVR.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.DIGISPARK_AVR.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.ESP32.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.ESP8266.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.SAM.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.SAMD21.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.SAMD51.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.STM32.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\hardware\uTimerLib.UNSUPPORTED.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src\uTimerLib.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\RunningAverage\RunningAverage.cpp
Using cached library dependencies for file: k:\9990 - Arduino\000 - CODE\libraries\PwmCompat\PwmCompat.cpp
Generating function prototypes...
C:\Users\micro\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/build_opt.h @C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/file_opts -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora -IC:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences\src -Ik:\9990 - Arduino\000 - CODE\libraries\Encoder -Ik:\9990 - Arduino\000 - CODE\libraries\OneButton\src -Ik:\9990 - Arduino\000 - CODE\libraries\LedController -Ik:\9990 - Arduino\000 - CODE\libraries\uTimerLib\src -Ik:\9990 - Arduino\000 - CODE\libraries\RunningAverage -Ik:\9990 - Arduino\000 - CODE\libraries\PwmCompat C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\sketch\RollerShadeController.ino.cpp -o C:\Users\micro\AppData\Local\Temp\153566027\sketch_merged.cpp
C:\Users\micro\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\micro\AppData\Local\Temp\153566027\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\s3-gcc\\2021r2-p5/bin/xtensa-esp32s3-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.7-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/include/" -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include "-IC:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include" -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -Og -g3 -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NANO_ESP32\"" "-DARDUINO_VARIANT=\"arduino_nano_nora\"" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Nano ESP32\"" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 "@C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/build_opt.h" "@C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/file_opts" "-IC:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\cores\\esp32" "-IC:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora" "-IC:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\libraries\\Preferences\\src" "-Ik:\\9990 - Arduino\\000 - CODE\\libraries\\Encoder" "-Ik:\\9990 - Arduino\\000 - CODE\\libraries\\OneButton\\src" "-Ik:\\9990 - Arduino\\000 - CODE\\libraries\\LedController" "-Ik:\\9990 - Arduino\\000 - CODE\\libraries\\uTimerLib\\src" "-Ik:\\9990 - Arduino\\000 - CODE\\libraries\\RunningAverage" "-Ik:\\9990 - Arduino\\000 - CODE\\libraries\\PwmCompat" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\sketch\\RollerShadeController.ino.cpp" -o "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\sketch\\RollerShadeController.ino.cpp.o"
Compiling libraries...
Compiling library "Preferences"
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\Preferences\Preferences.cpp.o
Compiling library "Encoder"
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\Encoder\Encoder.cpp.o
Compiling library "OneButton"
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\OneButton\OneButton.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\OneButton\OneButtonTiny.cpp.o
Compiling library "LedController"
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\LedController\LedController.cpp.o
Compiling library "uTimerLib"
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.ATTINY.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.SAMD51.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.ESP32.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.AVR.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.DIGISPARK_AVR.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.ESP8266.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.SAMD21.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.STM32.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.UNSUPPORTED.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\hardware\uTimerLib.SAM.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\uTimerLib\uTimerLib.cpp.o
Compiling library "RunningAverage"
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\RunningAverage\RunningAverage.cpp.o
Compiling library "PwmCompat"
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\libraries\PwmCompat\PwmCompat.cpp.o
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/file_opts"
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\core\double_tap.c.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\core\io_pin_remap.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\core\variant.cpp.o
Using previously compiled file: C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2\core\dfu_callbacks.cpp.o
Using precompiled core: C:\Users\micro\AppData\Local\arduino\cores\718caef5094513dee8ced30ff2bec06c\core.a
cmd /c type nul > "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/file_opts"
Linking everything together...
"C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\s3-gcc\\2021r2-p5/bin/xtensa-esp32s3-elf-g++" "-Wl,--Map=C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/RollerShadeController.ino.map" "-LC:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/lib" "-LC:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/ld" "-LC:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi" -T memory.ld -T sections.ld -T esp32s3.rom.ld -T esp32s3.rom.api.ld -T esp32s3.rom.libgcc.ld -T esp32s3.rom.newlib.ld -T esp32s3.rom.version.ld -T esp32s3.rom.newlib-time.ld -T esp32s3.peripherals.ld -mlongcalls -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -Wl,--wrap=esp_log_write -Wl,--wrap=esp_log_writev -Wl,--wrap=log_printf -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_var_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Nano ESP32\"" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 -Wl,--start-group "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\sketch\\RollerShadeController.ino.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\Preferences\\Preferences.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\Encoder\\Encoder.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\OneButton\\OneButton.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\OneButton\\OneButtonTiny.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\LedController\\LedController.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.ATTINY.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.AVR.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.DIGISPARK_AVR.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.ESP32.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.ESP8266.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.SAM.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.SAMD21.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.SAMD51.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.STM32.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\hardware\\uTimerLib.UNSUPPORTED.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\uTimerLib\\uTimerLib.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\RunningAverage\\RunningAverage.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\PwmCompat\\PwmCompat.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\core\\dfu_callbacks.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\core\\double_tap.c.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\core\\io_pin_remap.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\core\\variant.cpp.o" "C:\\Users\\micro\\AppData\\Local\\arduino\\cores\\718caef5094513dee8ced30ff2bec06c\\core.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lusb -lulp -lwifi_provisioning -lrmaker_common -lesp_diagnostics -lrtc_store -lesp_insights -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp32-camera -lesp_littlefs -lespressif__esp-dsp -lfb_gfx -lasio -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lusb -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_insights -lcbor -lesp_diagnostics -lrtc_store -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lqrcode -lrmaker_common -lmqtt -larduino_tinyusb -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lbtbb -lesp_phy -lphy -lbtbb -lesp_phy -lphy -lbtbb -lxt_hal -lc -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -Wl,--end-group -Wl,-EL -o "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/RollerShadeController.ino.elf"
"C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 16MB --elf-sha256-offset 0xb0 -o "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/RollerShadeController.ino.bin" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/RollerShadeController.ino.elf"
esptool.py v4.5.1
Creating esp32s3 image...
Merged 2 ELF sections
Successfully created esp32s3 image.
"C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\tools\\gen_esp32part.exe" -q "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/partitions.csv" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/RollerShadeController.ino.partitions.bin"
cmd /c if exist "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2\\libraries\\Insights" "C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\tools\\gen_insights_package.exe" "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2" RollerShadeController.ino "K:\\9990 - Arduino\\000 - CODE\\0000 - Project Shade Roller\\0000 - Arduino\\0100 - RollerShadeController\\RollerShadeController"
Using library Preferences at version 2.0.0 in folder: C:\Users\micro\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\libraries\Preferences
Using library Encoder at version 1.4.4 in folder: K:\9990 - Arduino\000 - CODE\libraries\Encoder
Using library OneButton at version 2.6.1 in folder: K:\9990 - Arduino\000 - CODE\libraries\OneButton
Using library LedController in folder: K:\9990 - Arduino\000 - CODE\libraries\LedController (legacy)
Using library uTimerLib at version 1.7.5 in folder: K:\9990 - Arduino\000 - CODE\libraries\uTimerLib
Using library RunningAverage at version 0.4.8 in folder: K:\9990 - Arduino\000 - CODE\libraries\RunningAverage
Using library PwmCompat in folder: K:\9990 - Arduino\000 - CODE\libraries\PwmCompat (legacy)
"C:\\Users\\micro\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\s3-gcc\\2021r2-p5/bin/xtensa-esp32s3-elf-size" -A "C:\\Users\\micro\\AppData\\Local\\arduino\\sketches\\BB745A3746AACD34F65664642D6E23D2/RollerShadeController.ino.elf"
Sketch uses 325093 bytes (10%) of program storage space. Maximum is 3145728 bytes.
Global variables use 32700 bytes (9%) of dynamic memory, leaving 294980 bytes for local variables. Maximum is 327680 bytes.
"C:\Users\micro\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5/dfu-util" --device 0x2341:0x0070 -D "C:\Users\micro\AppData\Local\arduino\sketches\BB745A3746AACD34F65664642D6E23D2/RollerShadeController.ino.bin" -Q
dfu-util 0.11-arduino4
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
Device ID 2341:0070
Device DFU version 0101
Claiming USB DFU Interface...
Setting Alternate Interface #0 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 0101
Device returned transfer size 4096
Copying data from PC to DFU device
Download	[                         ]   0%            0 bytes
Download	[=                        ]   4%        16384 bytes
Download	[==                       ]   8%        28672 bytes
Download	[===                      ]  12%        40960 bytes
Download	[====                     ]  16%        53248 bytes
Download	[=====                    ]  21%        69632 bytes
Download	[=====                    ]  23%        77824 bytes
Download	[======                   ]  24%        81920 bytes
Download	[=======                  ]  28%        94208 bytes
Download	[========                 ]  32%       106496 bytes
Download	[=========                ]  36%       118784 bytes
Download	[==========               ]  41%       135168 bytes
Download	[===========              ]  44%       147456 bytes
Download	[============             ]  48%       159744 bytes
Download	[=============            ]  52%       172032 bytes
Download	[==============           ]  57%       188416 bytes
Download	[===============          ]  60%       200704 bytes
Download	[================         ]  64%       212992 bytes
Download	[=================        ]  68%       225280 bytes
Download	[==================       ]  72%       237568 bytes
Download	[===================      ]  77%       253952 bytes
Download	[====================     ]  80%       266240 bytes
Download	[=====================    ]  84%       278528 bytes
Download	[======================   ]  88%       290816 bytes
Download	[=======================  ]  93%       307200 bytes
Download	[======================== ]  96%       319488 bytes
Download	[=========================] 100%       325456 bytes
Download done.
DFU state(7) = dfuMANIFEST, status(0) = No error condition is present
Done!
Get the board out of DFU mode and into 'normal' mode. Here is the google AI answer
and here is the Arduino docs that related to this
https://docs.arduino.cc/tutorials/nano-esp32/cheat-sheet/
Hi @martinrydahlpedersen.
Please provide a detailed description of exactly what it is you observed that led you to this conclusion.
If I e.g. upload the blink sketch, the device keeps blinking after a new upload. I have also tried altering the blink delays to ensure, it is the recently uploaded changes blink.
Yesterday I also tried uploading the AdvancedWebServer example (the one with MDNS and graph refreshing every 5 second). After upload of my sketch, and rebooting the device, I'm still able to reach the webserver at the IP address.
Since it also occours with a brand new device I tried with (I totally tried 2 different Nano ESP32s) - it must be my code. I just can't figure out why due to no (obvious) errors and DONE/OK/"Done uploading".
I don't know the architecture good enough to reason about it - but can it be because of different partitions or the like? Is it actualy being uploaded, so there somehow are 2 skethes in the device, but "wrong" instructions about whith sketch to execute?
Thx in advance :slight_smile:
Thank you. I already tried this several times - and use it when getting the error.
I just did't get this error initially with the device.
This error has started recently to show. It doesn't show at each upload, but happens frequently.
Thank you again.
Can you post it? I'm not a Nano ESP32 user so I can't help but others might be able to see issues.
There are plenty things that you can do wrong in your code that might result in undefined behaviour.
Right-click the folder containing all the files and click "Compress to ZIP"
Drag 'n drop the zipped file onto the post.
Leo..
You're right. I'll try. I also use other and own libraries, which are in other folders :+1:
