Arduino IDE not uploading the sketch
Hello All,
I am using Arduino Nano 33 BLE Sense.
Since yesterday, every time I upload a sketch , the IDE is throwing an error.
I have tried the following
  1. updated the IDE to v1.8.15
  2. updated the ArduinoBLE library to v1.2.1
  3. Uninstall and reinstalled the IDE as well.
Checked the port as well.
Please help as I am stuck and cant work.
Try uploading the Blink sketch
Is that the complete error message ?
Use the "Copy error message" button in the IDE and post it here using code tags
Thanks @UKHeliBob for reply.
I tried the Blink sketch. Still the same error.
Arduino: 1.8.15 (Windows 10), Board: "Arduino Nano 33 BLE"
Sketch uses 83384 bytes (8%) of program storage space. Maximum is 983040 bytes.
Global variables use 43920 bytes (16%) of dynamic memory, leaving 218224 bytes for local variables. Maximum is 262144 bytes.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
The error that you asked.
The next step is to enable verbose output during compilation and to post the output of the compilation and error here
Did that too. Same error
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\uic95085\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\uic95085\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries -fqbn=arduino:mbed_nano:nano33ble -vid-pid=2341_805A -ide-version=10815 -build-path C:\Users\uic95085\AppData\Local\Temp\arduino_build_683669 -warnings=none -build-cache C:\Users\uic95085\AppData\Local\Temp\arduino_cache_609310 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.rp2040tools.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.rp2040tools-1.0.2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.bossac.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.bossac-1.9.1-arduino2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.openocd.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.dfu-util.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\uic95085\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\uic95085\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries -fqbn=arduino:mbed_nano:nano33ble -vid-pid=2341_805A -ide-version=10815 -build-path C:\Users\uic95085\AppData\Local\Temp\arduino_build_683669 -warnings=none -build-cache C:\Users\uic95085\AppData\Local\Temp\arduino_cache_609310 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.rp2040tools.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.rp2040tools-1.0.2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.bossac.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.bossac-1.9.1-arduino2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.openocd.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.dfu-util.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'nano33ble' from platform in folder: C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\2.2.0
Using core 'arduino' from platform in folder: C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\2.2.0
Detecting libraries used...
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669\\sketch\\Blink.ino.cpp" -o "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -MMD -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669\\sketch\\Blink.ino.cpp" -o "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_683669\core\variant.cpp.o
Using precompiled core: C:\Users\uic95085\AppData\Local\Temp\arduino_cache_609310\core\core_arduino_mbed_nano_nano33ble_df0a1fec2a1c9c588d37fa35137c3990.a
Linking everything together...
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669" -Wl,--gc-sections -w -Wl,--as-needed "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/ldflags.txt" "-TC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/linker_script.ld" "-Wl,-Map,C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669/Blink.ino.map" --specs=nosys.specs -o "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669/Blink.ino.elf" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669\\sketch\\Blink.ino.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669\\core\\variant.cpp.o" -Wl,--whole-archive "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669/..\\arduino_cache_609310\\core\\core_arduino_mbed_nano_nano33ble_df0a1fec2a1c9c588d37fa35137c3990.a" "C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/libs/libmbed.a" "C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/libs/libcc_310_core.a" "C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/libs/libcc_310_ext.a" "C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/libs/libcc_310_trng.a" -Wl,--no-whole-archive -Wl,--start-group -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669/Blink.ino.elf" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669/Blink.ino.bin"
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669/Blink.ino.elf" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669/Blink.ino.hex"
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_683669/Blink.ino.elf"
This is a difficult problem to troubleshoot because there is no useful output from the upload process to help us understand what went wrong.
When I have no idea what the problem is, I must fall back on the old standard. Please restart your computer and then try uploading again. Let us know whether that fixes the error.
Thanks @pert ,
It worked and I even reset the boards.
Any way to avoid it in future.
Thanks to both for help :slightly_smiling_face:
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
One new thing @pert
I am trying to upload the attached code.
While compilation, it shows no error but when i upload it it shows an error like the previous one.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\uic95085\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\uic95085\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries -fqbn=arduino:mbed_nano:nano33ble -vid-pid=2341_805A -ide-version=10815 -build-path C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471 -warnings=none -build-cache C:\Users\uic95085\AppData\Local\Temp\arduino_cache_377649 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.bossac-1.9.1-arduino2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.dfu-util.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.rp2040tools.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.rp2040tools-1.0.2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.openocd.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -verbose C:\Users\uic95085\OneDrive - Continental AG\Desktop\projects\Arduino code\temp_in_adv\temp_in_adv.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\uic95085\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\uic95085\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries -fqbn=arduino:mbed_nano:nano33ble -vid-pid=2341_805A -ide-version=10815 -build-path C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471 -warnings=none -build-cache C:\Users\uic95085\AppData\Local\Temp\arduino_cache_377649 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.bossac-1.9.1-arduino2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.dfu-util.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.rp2040tools.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.rp2040tools-1.0.2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2 -prefs=runtime.tools.openocd.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -verbose C:\Users\uic95085\OneDrive - Continental AG\Desktop\projects\Arduino code\temp_in_adv\temp_in_adv.ino
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp" -o nul
Alternatives for Arduino_LPS22HB.h: [Arduino_LPS22HB@1.0.1]
ResolveLibrary(Arduino_LPS22HB.h)
  -> candidates: [Arduino_LPS22HB@1.0.1]
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp" -o nul
Alternatives for Wire.h: [Wire]
ResolveLibrary(Wire.h)
  -> candidates: [Wire]
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\libraries\\Wire" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp" -o nul
Alternatives for Arduino_HTS221.h: [Arduino_HTS221@1.0.0]
ResolveLibrary(Arduino_HTS221.h)
  -> candidates: [Arduino_HTS221@1.0.0]
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\libraries\\Wire" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp" -o nul
Alternatives for ArduinoBLE.h: [ArduinoBLE-master@1.1.3 ArduinoBLE@1.2.1]
ResolveLibrary(ArduinoBLE.h)
  -> candidates: [ArduinoBLE-master@1.1.3 ArduinoBLE@1.2.1]
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\libraries\\Wire" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\ArduinoBLE\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\Arduino_LPS22HB\src\BARO.cpp
Using cached library dependencies for file: C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\2.2.0\libraries\Wire\Wire.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\Arduino_HTS221\src\HTS.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\BLEAdvertisingData.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\BLECharacteristic.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\BLEDescriptor.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\BLEDevice.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\BLEService.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\BLEStringCharacteristic.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\BLETypedCharacteristics.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\local\BLELocalAttribute.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\local\BLELocalCharacteristic.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\local\BLELocalDescriptor.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\local\BLELocalDevice.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\local\BLELocalService.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\remote\BLERemoteAttribute.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\remote\BLERemoteCharacteristic.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\remote\BLERemoteDescriptor.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\remote\BLERemoteDevice.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\remote\BLERemoteService.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\utility\ATT.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\utility\BLEUuid.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\utility\GAP.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\utility\GATT.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\utility\HCI.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\utility\HCIUartTransport.cpp
Using cached library dependencies for file: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE\src\utility\L2CAPSignaling.cpp
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\libraries\\Wire" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\ArduinoBLE\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp" -o "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/defines.txt" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/cxxflags.txt" -DARDUINO_ARCH_NRF52840 -MMD -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -DARDUINO=10815 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\libraries\\Wire" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Users\\uic95085\\OneDrive - Continental AG\\Documents\\Arduino\\libraries\\ArduinoBLE\\src" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\cores\\arduino" "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/includes.txt" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp" -o "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp.o"
Compiling library "Arduino_LPS22HB"
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\Arduino_LPS22HB\BARO.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\Wire\Wire.cpp.o
Compiling library "Arduino_HTS221"
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\Arduino_HTS221\HTS.cpp.o
Compiling library "ArduinoBLE"
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\BLEAdvertisingData.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\BLEDescriptor.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\BLECharacteristic.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\BLEDevice.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\BLEService.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\BLEStringCharacteristic.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\BLETypedCharacteristics.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\local\BLELocalDescriptor.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\local\BLELocalDevice.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\local\BLELocalCharacteristic.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\local\BLELocalAttribute.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\local\BLELocalService.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\remote\BLERemoteDescriptor.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\remote\BLERemoteDevice.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\remote\BLERemoteCharacteristic.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\remote\BLERemoteAttribute.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\remote\BLERemoteService.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\utility\BLEUuid.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\utility\GATT.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\utility\ATT.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\utility\GAP.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\utility\HCIUartTransport.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\utility\L2CAPSignaling.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\utility\HCI.cpp.o
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\libraries\ArduinoBLE\utility\HCICordioTransport.cpp.o
Compiling core...
Using previously compiled file: C:\Users\uic95085\AppData\Local\Temp\arduino_build_288471\core\variant.cpp.o
Using precompiled core: C:\Users\uic95085\AppData\Local\Temp\arduino_cache_377649\core\core_arduino_mbed_nano_nano33ble_df0a1fec2a1c9c588d37fa35137c3990.a
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471" -Wl,--gc-sections -w -Wl,--as-needed "@C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/ldflags.txt" "-TC:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/linker_script.ld" "-Wl,-Map,C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471/temp_in_adv.ino.map" --specs=nosys.specs -o "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471/temp_in_adv.ino.elf" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\sketch\\temp_in_adv.ino.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\Arduino_LPS22HB\\BARO.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\Arduino_HTS221\\HTS.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\BLEAdvertisingData.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\BLECharacteristic.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\BLEDescriptor.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\BLEDevice.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\BLEService.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\BLEStringCharacteristic.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\BLETypedCharacteristics.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\local\\BLELocalAttribute.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\local\\BLELocalCharacteristic.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\local\\BLELocalDescriptor.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\local\\BLELocalDevice.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\local\\BLELocalService.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\remote\\BLERemoteAttribute.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\remote\\BLERemoteCharacteristic.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\remote\\BLERemoteDescriptor.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\remote\\BLERemoteDevice.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\remote\\BLERemoteService.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\utility\\ATT.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\utility\\BLEUuid.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\utility\\GAP.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\utility\\GATT.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\utility\\HCI.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\utility\\HCICordioTransport.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\utility\\HCIUartTransport.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\libraries\\ArduinoBLE\\utility\\L2CAPSignaling.cpp.o" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471\\core\\variant.cpp.o" -Wl,--whole-archive "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471/..\\arduino_cache_377649\\core\\core_arduino_mbed_nano_nano33ble_df0a1fec2a1c9c588d37fa35137c3990.a" "C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/libs/libmbed.a" "C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/libs/libcc_310_core.a" "C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/libs/libcc_310_ext.a" "C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\2.2.0\\variants\\ARDUINO_NANO33BLE/libs/libcc_310_trng.a" -Wl,--no-whole-archive -Wl,--start-group -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471/temp_in_adv.ino.elf" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471/temp_in_adv.ino.bin"
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471/temp_in_adv.ino.elf" "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471/temp_in_adv.ino.hex"
Multiple libraries were found for "ArduinoBLE.h"
 Used: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE
 Not used: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE-master
Using library Arduino_LPS22HB at version 1.0.1 in folder: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\Arduino_LPS22HB
Using library Wire in folder: C:\Users\uic95085\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\2.2.0\libraries\Wire (legacy)
Using library Arduino_HTS221 at version 1.0.0 in folder: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\Arduino_HTS221
Using library ArduinoBLE at version 1.2.1 in folder: C:\Users\uic95085\OneDrive - Continental AG\Documents\Arduino\libraries\ArduinoBLE
"C:\\Users\\uic95085\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\uic95085\\AppData\\Local\\Temp\\arduino_build_288471/temp_in_adv.ino.elf"
Sketch uses 319504 bytes (32%) of program storage space. Maximum is 983040 bytes.
Global variables use 70888 bytes (27%) of dynamic memory, leaving 191256 bytes for local variables. Maximum is 262144 bytes.
temp_in_adv.ino (1.3 KB)
Any idea why this is happening? Please help !
The IDE gets hang afterwards.
Unfortunately, I don't know what could be the cause of this problem. I see reports like this here on the forum from time to time and have never seen a satisfying solution presented.
I can give you my other standard advice for when there is a mysterious problem I don't have an explanation for:
This sort of error could be caused by your antivirus software. Try TEMPORARILY disabling your antivirus for a single upload to see if the problem goes away, then turn the antivirus back on.
If the problem doesn't occur with the antivirus off you will need to adjust the settings of your antivirus to put the appropriate file, folder, or process on the "allow list" so it doesn't interfere with the upload.
Please be cautious about working without an antivirus. This is only about temporarily disabling it for a quick test. If you don't feel comfortable doing that, fine. You can try going straight to configuring the antivirus to not interfere with the Arduino software.
Thanks @pert ,
I will check into it, and see if it helps!.
Thanks for help !
EDIT: Flashing bootloader fixed the problem.
Helo,
It seem I have similar problem. I have Arduino Uno and Arduino Leonardo. I had no previous problems with those boards, I've been using them for years. Recently, after windows update I found that I'm unable to upload any Arduino sketch. I tried using Platform IO and Arduino IDE 1.8.15. I also tried to reinstall Arduino drivers. The board are recognized by mi system and appear in COM devices list. When uploading starts RX diode blinks 2 times and then nothing.
My OS:
Windows 10 Home 20H2
Log from Arduino IDE :
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Kuba\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Kuba\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Kuba\Documents\Arduino\libraries -fqbn=arduino:avr:leonardo -vid-pid=2341_0043 -ide-version=10815 -build-path C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360 -warnings=none -build-cache C:\Users\Kuba\AppData\Local\Temp\arduino_cache_969894 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Kuba\Documents\Arduino\libraries\ArduinoTasker\examples\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Kuba\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Kuba\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Kuba\Documents\Arduino\libraries -fqbn=arduino:avr:leonardo -vid-pid=2341_0043 -ide-version=10815 -build-path C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360 -warnings=none -build-cache C:\Users\Kuba\AppData\Local\Temp\arduino_cache_969894 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Kuba\Documents\Arduino\libraries\ArduinoTasker\examples\Blink\Blink.ino
Using board 'leonardo' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Leonardo"" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\leonardo" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\Blink.ino.cpp" -o nul
Alternatives for TaskManager.h: [ArduinoTasker@0.0.0]
ResolveLibrary(TaskManager.h)
-> candidates: [ArduinoTasker@0.0.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Leonardo"" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\leonardo" "-IC:\Users\Kuba\Documents\Arduino\libraries\ArduinoTasker\src" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\Blink.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\LedBlinkTask.cpp
Using cached library dependencies for file: C:\Users\Kuba\Documents\Arduino\libraries\ArduinoTasker\src\Task.cpp
Using cached library dependencies for file: C:\Users\Kuba\Documents\Arduino\libraries\ArduinoTasker\src\TaskManager.cpp
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Leonardo"" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\leonardo" "-IC:\Users\Kuba\Documents\Arduino\libraries\ArduinoTasker\src" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\Blink.ino.cpp" -o "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\preproc\ctags_target_for_gcc_minus_e.cpp"
Kompilowanie szkicu...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER="Unknown"" "-DUSB_PRODUCT="Arduino Leonardo"" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\leonardo" "-IC:\Users\Kuba\Documents\Arduino\libraries\ArduinoTasker\src" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\Blink.ino.cpp" -o "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\Blink.ino.cpp.o"
Użycie wcześniej skompilowanego pliku: C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\LedBlinkTask.cpp.o
Compiling library "ArduinoTasker"
Użycie wcześniej skompilowanego pliku: C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\libraries\ArduinoTasker\Task.cpp.o
Użycie wcześniej skompilowanego pliku: C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\libraries\ArduinoTasker\TaskManager.cpp.o
Compiling core...
Using precompiled core: C:\Users\Kuba\AppData\Local\Temp\arduino_cache_969894\core\core_arduino_avr_leonardo_0c812875ac70eb4a9b385d8fb077f54c.a
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360/Blink.ino.elf" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\Blink.ino.cpp.o" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\sketch\LedBlinkTask.cpp.o" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\libraries\ArduinoTasker\Task.cpp.o" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360\libraries\ArduinoTasker\TaskManager.cpp.o" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360/..\arduino_cache_969894\core\core_arduino_avr_leonardo_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\Kuba\AppData\Local\Temp\arduino_build_296360" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360/Blink.ino.elf" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360/Blink.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360/Blink.ino.elf" "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360/Blink.ino.hex"
Użycie biblioteki ArduinoTasker w wersji 0.0.0 z folderu: C:\Users\Kuba\Documents\Arduino\libraries\ArduinoTasker
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size" -A "C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360/Blink.ino.elf"
Szkic używa 6552 bajtów (22%) pamięci programu. Maksimum to 28672 bajtów.
Zmienne globalne używają 205 bajtów (8%) pamięci dynamicznej, pozostawiając 2355 bajtów dla zmiennych lokalnych. Maksimum to 2560 bajtów.
Wymuszam reset używając 1200bps otwórz/zamknij na porcie COM4
PORTS {COM1, COM4, } / {COM1, COM4, } => {}
Uploading using selected port: COM4
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM4 -b57600 -D -Uflash:w:C:\Users\Kuba\AppData\Local\Temp\arduino_build_296360/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
     Using Port                    : COM4
     Using Programmer              : avr109
     Overriding Baud Rate          : 57600
     AVR Part                      : ATmega32U4
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PA0
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
       lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : butterfly
     Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "F"; type = @
Software Version = �.v; Hardware Version = �.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done. Thank you.
wybrany port szeregowy
nie istnieje albo Twoja płytka nie jest podłączona
