Hi there.
Just getting set up for the first time, and have hit a brick wall.
When compiling the example Blink, I get the error:
In file included from Blink.cpp:8:
C:\Documents and Settings\david.clarke\My Documents\Downloads\Arduino\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino/Arduino.h:212:26: error: pins_arduino.h: No such file or directory
My environment:
Board: Arduino Ethernet
OS: Windows XP
Arduino version: 1.0
I have replaced my boards.txt with one from http://arduino.cc/en/uploads/Main/boards.txt and have selected Arduino Ethernet in the Arduino environment.
I can see various pins_arduino.h in C:\Documents and Settings\david.clarke\My Documents\Downloads\Arduino\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard, micro, mega, leonardo and eightanalogueinputs.
In case it's relevant, this is the Arduino Ethernet section of my boards.txt:
uno.name=Arduino Ethernet (with USB2Serial module)
uno.upload.protocol=stk500
uno.upload.maximum_size=32256
uno.upload.speed=115200
uno.bootloader.low_fuses=0xff
uno.bootloader.high_fuses=0xde
uno.bootloader.extended_fuses=0x05
uno.bootloader.path=optiboot
uno.bootloader.file=optiboot_atmega328.hex
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.build.mcu=atmega328p
uno.build.f_cpu=16000000L
uno.build.core=arduino
What am I not configuring here?
