Hello guys, my name is shoham and I have an issue i cant solve that i would like your help with.
I have 2 arduino nano's. onw of them has type C entrence and is working fine' i can uplaod scketches, detect it in device maneger and all. unfortunatly the other one i have does not. It has micro usb enrence and when i connect it to the same usb port that the first arduino worked in i cant detect it in device maneger, i cant see the port in the IDE (just dont have the menu to open) and it has 2 leds on- the "ON" led and the "RX" led although nothing is connected to any pin.
Your older Nano might have a different comm chip. Look on the bottom side for the many-leg I.C. and the printing to say "FTDI" or "CH340"... If it is CH340, you will need to download and install the driver (I think it is called CH341).
well guys it's a bit imberresing but after checking almost every cable i had at home problem solved, i guess it really wasnt a data cable. thank you all for the quick answers!
