I'm trying to add two SHT10 sensors to a much larger project but cannot figure out how to read from 2 sensors independently. I'm using the sensirion library found at Sensirion Github .
I'm fairly new to this and every attempt to change this code for 2 sensors does not work. Any help would be appreciated.
This is the code:
#include <Sensirion.h>
const uint8_t dataPin = 5;
const uint8_t clockPin = 6;
float temperature;
float humidity;
float dewpoint;
Sensirion tempSensor = Sensirion(dataPin, clockPin);
tempSensor.measure(&temperature, &humidity, &dewpoint);
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.print(" C, Humidity: ");
Serial.print(humidity);
Serial.print(" %, Dewpoint: ");
Serial.print(dewpoint);
Serial.println(" C");
delay(5000);
I looked on your schematic and could not find the second data pin. With both connected as the software indicates you will get garbage.
DaveX
April 11, 2023, 1:47am
3
Does it work for one sensor?
Schematic?
Where do you have the second sensor attached?
Your code looks almost exactly like https://github.com/spease/Sensirion/blob/master/examples/SimpleSensirion/SimpleSensirion.pde
I think the main change you need is near this line:
...you need to instantiate another sensor with a different name on different pins with a line like this completely untested line:
Sensirion tempSensor2 = Sensirion(dataPin2, clockPin2);
What have you tried? And how has it failed?
Yes it does
DaveX:
Schematic?
Pins 6 and 7
It is. I'm trying to get the simple code working with 2 sensors.
My problem is
cuparguy:
How do i distinguish the 2 sensors from each other?
I will give try in the AM. Thank You
Completely forgot to update this but thank you.
I did not notice the 2 after each at first. It was easy as that. I'm learning a lot.
system
Closed
October 19, 2023, 3:53pm
8
