Can't flash ESP32-C3 via OTA/ wifi
Hello y'all!
I managed to get a few ESP32-C3 boards from aliexpress before the tarrifs, and everything is working great so far, except programming via OTA / wifi.
Thats the board that I bought:
https://www.aliexpress.us/item/32568073 ... pt=glo2usa
What I did so far:
  • flash the OTAbasic sample from the Arduino IDE via usb-c (ssid and pw are set)
  • verify that the esp32 got assigned an IP address
  • I can successfully ping the esp32
Then I try to flash the same sketch, but this time I select the ESP32 @192.168.0.197 from the "port" menu.
Compiling starts, but after a while it always errors out with :
Uploading: [========= ] 15%
13:53:23 [ERROR]: Error Uploading: [Errno 32] Broken pipe
Failed uploading: uploading error: exit status 1
After that happened, I cant ping the esp32 anymore and it needs a power cycle...
Not sure if it makes sense to provide the sketch that I used, as its the standard sample that comes with the arduino ide.
Wifi and power supply are both stable. Flashing via USB-C works like a charm....
Any ideas what the issue might be?
Thx in advance!
Sebastian
How are the firewall settings for esptool.py ?
I am not using a firewall on this macbook.
Anything in the router ?
If you set up the esp32 as an Access Point and connect the laptop to it instead of through the router, does that help ?
need to google how to do this. thx for the tip.
but still.. shouldnt it also work "just like this"?
Now it worked for like 3-4 minutes, and then it errored out at 61%
Other wifi traffic on the router may be disturbing the upload. Hence the suggestion of making a direct WiFi connection with the ESP
