Hi all, I'm totally new to all this arduino stuff and am having problems flashing firmware to my nano ble 33 sense rev2 so I can use micropython. Initially, I had everything running fine but needed to reinstall everything to get something working. Since then I cannot get micropython working again. The micropython installer recognizes the board but fails to flash the firmware. Arduino labs for micropython can't connect at all, however the arduino IDE and code still works perfectly fine with the board. I've tried everything I can for days but nothing works. Does anybody have a solution to get micropython running again? Thanks!
@brjohnson123 did you put the microcontroller into bootloader mode before you tried using the micropython installer. Double press the reset button quickly two times and the green led should start blinking .
Are you following the steps from here?
Tried that but no luck
Yes, I installed the firmware from there but arduino labs still can't connect.
When trying to access using Thonny, I get this message
Device is busy or does not respond. Your options:
- wait until it completes current work;
- use Ctrl+C to interrupt current work;
- reset the device and try again;
- check connection properties;
- make sure the device has suitable MicroPython / CircuitPython / firmware;
- make sure the device is not in bootloader mode.
Could not interrupt current process. Please wait, try again or select Stop/Restart!
Okay, sorry. I don't have a nano ble 33 sense to try. I've only done it for an ESP32 dev kit for which the detailed instructions worked well and for the Raspberry Pi Pico W where it is a simple drag and drop in DFU mode and both worked well.
If the IDE still uploads but Micropython won’t flash, the board is probably stuck in the wrong bootloader mode. Try double-tapping reset to enter the UF2 bootloader, then flash the Micropython UF2 file directly. If the installer still fails, erase the board using the Arduino CLI and retry. Many Nano 33 BLE boards only load Micropython reliably when flashed from a clean bootloader state.
Did you install the bootloader from here?
