Hello
I got a 5 meter led strip from aliexpress, it seems it is a ws2811 strip where each chip control 36 leds, total 720 leds.
I can't get it to work properly, when i tell it to do red, it does green for example, and it's not always consistent, meaning it sometimes just does some random color even i didnt program it to make a different color.
Also the first chip just does something different, its always different from the rest.
I've been using the FastLED library
I also tried the Adafruit_NeoPixel library, with this one sometimes it stutters
This strip shares ground and 12v to a different strip, a ws2815, this ws2815 seems to work fine, i'm not sure if having it connecting like this may be causing problems
I tried different pixel format like BGR and RBG, none seem to fix the issue
Here's the test sketch
#include <FastLED.h>
#define LED_PIN 25 // Replace with the pin number you used for DATA connection
#define NUM_LEDS 100 // Replace with the number of LEDs in your strip
CRGB leds[NUM_LEDS];
FastLED.addLeds<WS2811, LED_PIN, GRB >(leds, NUM_LEDS);
FastLED.setBrightness(255);
for (int i = 0; i < NUM_LEDS; i++)
leds[i] = CRGB::Red;
FastLED.show();
leds[i] = CRGB::Green;
FastLED.show();
leds[i] = CRGB::Blue;
FastLED.show();
leds[i] = CRGB::Black;
FastLED.show();
with that sketch, this is what the strip does:
Any help? thanks
