Hi Guys,
Relatively new to Arduino but have used the advice from the board many times.
I am however stuck with my current sketch and need some advice please. This is an install in a 1/76 scale bus where bluetooth application sets either the destination (written to the OLED screen) or activates one of the lighting features (headlights, blinkers etc).
The issue - IND_On turns on the blinkers but they are solid, not flashing as required. I can use Delay but this causes a block and I can't do anything else while that action runs. Can Millis be used to complete this request?
My code in it's entirety is below. Any help much appreciated:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
unsigned long previousMillis = 0;
int ledState = LOW; //initial state of LED
long rememberTime = 0;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// 'Harry_Potter_logo_text (1)', 128x32px
const unsigned char myBitmap [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0e, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x78, 0x00, 0x20, 0x0e, 0x70, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x1e, 0x30, 0x08, 0x78, 0x0e, 0x70, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x31, 0x1f, 0x7c, 0x0e, 0x70, 0x3e, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x37, 0x9f, 0xec, 0x0e, 0x70, 0x3f, 0xc6, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x37, 0xcf, 0xe8, 0x0e, 0x73, 0x9f, 0xeb, 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x32, 0xef, 0x60, 0xef, 0xf7, 0xdd, 0xdb, 0xec, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x30, 0xec, 0x7c, 0xcf, 0xff, 0xdd, 0xd9, 0xe8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x3f, 0xec, 0x6c, 0xcf, 0xee, 0xd9, 0xdf, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x3f, 0xec, 0x6e, 0x8f, 0x0e, 0xd9, 0xd8, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x4e, 0x77, 0xec, 0x6f, 0x8f, 0x0e, 0xd9, 0xd8, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x2f, 0xf7, 0xec, 0x6f, 0x0f, 0x0e, 0xd9, 0xd8, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x1f, 0x37, 0xec, 0xe7, 0x07, 0x0e, 0xd9, 0xdb, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x33, 0xfe, 0x06, 0x0e, 0x06, 0xd9, 0xce, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x33, 0xc0, 0x06, 0x0e, 0x03, 0xd9, 0xc6, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x30, 0x0e, 0x0c, 0x0e, 0x00, 0x09, 0xc0, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x30, 0x0c, 0x0c, 0x0e, 0x00, 0x04, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x30, 0x0f, 0xf8, 0x0e, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x30, 0x03, 0xf8, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0e, 0x70, 0x00, 0x20, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x78, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
String readString;
int state = 0;
Serial.begin(9600); // Default communication rate of the Bluetooth module
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(11, OUTPUT); // define LEDpin as output
digitalWrite(11, LOW); // set initial state
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //or 0x3C
display.clearDisplay(); //for Clearing the display
display.drawBitmap(40, 0, myBitmap, 128, 32, WHITE); // display.drawBitmap(x position, y position, bitmap data, bitmap width, bitmap height, color)
display.display();
while (Serial.available()) {
delay(50);
char c = Serial.read();
readString += c;
if (readString.length() > 0) {
Serial.println(readString);
if (readString == "Dest_1") {
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(40, 8);
// Display static text
display.println("Desination 1");
display.display();
if (readString == "Dest_2") {
display.setCursor(30, 4);
display.println("Aldershot");
display.display();
display.setCursor(24, 12);
display.println("via Old Dean");
display.display();
display.setTextSize(2);
display.setCursor(110, 5);
display.println("1");
display.display();
if (readString == "Dest_3") {
display.setCursor(24, 8);
display.println("Destination 3");
display.display();
display.setCursor(98, 4);
display.println("99");
display.display();
if (readString == "Dest_4") {
display.display();
if (readString == "HL_On") {
digitalWrite(12, HIGH);
if (readString == "HL_Off") {
digitalWrite(12, LOW);
if (readString == "IND_On")
digitalWrite(11, (millis() % 500) < 250 ? HIGH : LOW);
if (readString == "IND_Off") {
readString = "";
