I'm working on communicating with a AD9833 DDS chip and have not been able to get it to work. After reading up on how to do hardware spi, I came up with the following code. Also, from a data sheet I discovered that I need to send the following bits to the DDS chip:
0010 0001 0000 0000
0101 0000 1100 0111
0100 0000 0000 0000
1100 0000 0000 0000
0010 0000 0000 0000
Here's the code I have so far:
#define DATAOUT 11 //MOSI
#define DATAIN 12 //MISO
#define SPICLOCK 13 //sck
#define SLAVESELECT 10 //ss
//opcodes
#define WREN 6
#define WRDI 4
#define RDSR 5
#define WRSR 1
#define READ 3
#define WRITE 2
byte eeprom_output_data;
byte eeprom_input_data=0;
byte clr;
int address=0;
//data buffer
char buffer [128];
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))) // Wait the end of the transmission
return SPDR; // return the received byte
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(SLAVESELECT,OUTPUT);
digitalWrite(SLAVESELECT,HIGH); //disable device
// SPCR = 01010000
//interrupt disabled,spi enabled,msb 1st,master,clk low when idle,
//sample on leading edge of clk,system clock/4 rate (fastest)
SPCR = (1<<SPE)|(1<<MSTR);
clr=SPSR;
clr=SPDR;
delay(10);
digitalWrite(SLAVESELECT,LOW);
spi_transfer((char)(8448>>8)); //send MSByte first
spi_transfer((char)(8448)); //send LSByte
delay(10);
spi_transfer((char)(20679>>8)); //send MSByte first
spi_transfer((char)(20679)); //send LSByte
delay(10);
spi_transfer((char)(16384>>8)); //send MSByte first
spi_transfer((char)(16384)); //send LSByte
delay(10);
spi_transfer((char)(49152>>8)); //send MSByte first
spi_transfer((char)(49152)); //send LSByte
delay(10);
spi_transfer((char)(8192>>8)); //send MSByte first
spi_transfer((char)(8192)); //send LSByte
delay(500); //pause for readability
Also, the DDS chips data sheet says :
When data is being transmitted to the AD9833, the FSYNC line is taken low (PC7). Serial data from the 68HC11/68L11 is transmitted in 8-bit bytes with only eight falling clock edges occurring in the transmit cycle. Data is transmitted MSB first. To load data into the AD9833, PC7 is held low after the first 8 bits are transferred, and a second serial write operation is performed to the AD9833. Only after the second 8 bits have been transferred should FSYNC be taken high again.
If anyone has any idea what I'm doing wrong, please let me know, it will help me immensely and I will be very grateful.
Thanks,
Chris
