Program is exactly as in the example, except that I've put my SSID and password as strings in the program.
There were quite a few compiler warnings. Last few lines of the output:
Linking everything together...
/Users/david/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -E -P -x c -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 /Users/david/Library/Arduino15/packages/arduino/hardware/mbed_giga/4.0.2/variants/GIGA/linker_script.ld -o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/linker_script.ld
/Users/david/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -L/var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593 -Wl,--gc-sections -Wl,--as-needed -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 @/Users/david/Library/Arduino15/packages/arduino/hardware/mbed_giga/4.0.2/variants/GIGA/ldflags.txt -T/var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/linker_script.ld -Wl,-Map,/var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/GIGAWiFiWebServer.ino.map --specs=nosys.specs -o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/GIGAWiFiWebServer.ino.elf /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/sketch/GIGAWiFiWebServer.ino.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/SPI/SPI.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/WiFi/WiFi.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/WiFi/WiFiServer.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/SocketWrapper/MbedClient.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/SocketWrapper/MbedSSLClient.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/SocketWrapper/MbedServer.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/SocketWrapper/MbedUdp.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/SocketWrapper/SocketHelpers.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/libraries/SocketWrapper/utility/http_parser/http_parser.c.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/core/pure_analog_pins.cpp.o /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/core/variant.cpp.o -Wl,--whole-archive /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/core/core.a /Users/david/Library/Arduino15/packages/arduino/hardware/mbed_giga/4.0.2/variants/GIGA/libs/libmbed.a -Wl,--no-whole-archive -Wl,--start-group -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group
/Users/david/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/GIGAWiFiWebServer.ino.elf /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/GIGAWiFiWebServer.ino.bin
/Users/david/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/GIGAWiFiWebServer.ino.elf /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/GIGAWiFiWebServer.ino.hex
Multiple libraries were found for "WiFi.h"
Used: /Users/david/Library/Arduino15/packages/arduino/hardware/mbed_giga/4.0.2/libraries/WiFi
Not used: /Users/david/Documents/Arduino/libraries/WiFiNINA
Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi
Using library SPI in folder: /Users/david/Library/Arduino15/packages/arduino/hardware/mbed_giga/4.0.2/libraries/SPI (legacy)
Using library WiFi at version 1.0 in folder: /Users/david/Library/Arduino15/packages/arduino/hardware/mbed_giga/4.0.2/libraries/WiFi
Using library SocketWrapper at version 1.0 in folder: /Users/david/Library/Arduino15/packages/arduino/hardware/mbed_giga/4.0.2/libraries/SocketWrapper
/Users/david/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /var/folders/fd/7rbn3jxx5j942sk5kn0vhb740000gn/T/arduino_build_914593/GIGAWiFiWebServer.ino.elf
Sketch uses 269436 bytes (13%) of program storage space. Maximum is 1966080 bytes.
Global variables use 63792 bytes (12%) of dynamic memory, leaving 459832 bytes for local variables. Maximum is 523624 bytes.
