I am using a Teensy 2.0 with WS2801 Leds.
I have uploaded this code to the Teensy 2.0. I took it from Github for Adafruit project.
I am currently using 40 leds with a 5V 8A DC supply.
The Leds are disposed in a rectangle of 16*4 and it is designed to go in my PC Tower.
As you can see, all the Leds are not lighted up.
If i do understand the following code, it supposed to light up the first 25000 LEDs -.-
But what is weird to me it that for example, LED 30 is lighted up LED 31 is not, LED 32 is not but LED 33 is. Doesn't make any sense to me why it is "jumping" some LEDs.
I tried to modify the code, but it seems not to change a thing since i am a real newbie to this. So with all the kindness i can offer, i am asking for your help.
Thank you mates.
#include <SPI.h>
// LED pin for Adafruit 32u4 Breakout Board:
//#define LED_DDR DDRE
//#define LED_PORT PORTE
//#define LED_PIN _BV(PORTE6)
// LED pin for Teensy:
#define LED_DDR DDRD
#define LED_PORT PORTD
#define LED_PIN _BV(PORTD6)
// LED pin for Arduino:
//#define LED_DDR DDRB
//#define LED_PORT PORTB
//#define LED_PIN _BV(PORTB5)
static const uint8_t magic[] = {'A','d','a'};
#define MAGICSIZE sizeof(magic)
#define HEADERSIZE (MAGICSIZE + 3)
#define MODE_HEADER 0
#define MODE_HOLD 1
#define MODE_DATA 2
static const unsigned long serialTimeout = 15000; // 15 seconds
uint8_t
buffer[256],
indexIn = 0,
indexOut = 0,
mode = MODE_HEADER,
hi, lo, chk, i, spiFlag;
int16_t
bytesBuffered = 0,
hold = 0,
c;
int32_t
bytesRemaining;
unsigned long
startTime,
lastByteTime,
lastAckTime,
t;
LED_DDR |= LED_PIN; // Enable output for LED
LED_PORT &= ~LED_PIN; // LED off
Serial.begin(115200); // Teensy/32u4 disregards baud rate; is OK!
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
SPI.setClockDivider(SPI_CLOCK_DIV16); // 1 MHz max, else flicker
uint8_t testcolor[] = { 8, 16, 32, 64, 128, 255 };
for(char n=3; n>=0; n--) {
for(c=0; c<20; c++) {
for(i=0; i<3; i++) {
for(SPDR = testcolor[n + i]; !(SPSR & _BV(SPIF)); );
delay(1); // One millisecond pause = latch
Serial.print("Ada\n"); // Send ACK string to host
startTime = micros();
lastByteTime = lastAckTime = millis();
for(;;) {
t = millis();
if((bytesBuffered < 256) && ((c = Serial.read()) >= 0)) {
buffer[indexIn++] = c;
bytesBuffered++;
lastByteTime = lastAckTime = t; // Reset timeout counters
// No data received. If this persists, send an ACK packet
// to host once every second to alert it to our presence.
if((t - lastAckTime) > 1000) {
lastAckTime = t; // Reset counter
// If no data received for an extended time, turn off all LEDs.
if((t - lastByteTime) > serialTimeout) {
for(c=0; c<32767; c++) {
for(SPDR=0; !(SPSR & _BV(SPIF)); );
lastByteTime = t; // Reset counter
switch(mode) {
case MODE_HEADER:
// In header-seeking mode. Is there enough data to check?
if(bytesBuffered >= HEADERSIZE) {
// Indeed. Check for a 'magic word' match.
for(i=0; (i<MAGICSIZE) && (buffer[indexOut++] == magic[i++]););
if(i == MAGICSIZE) {
// Magic word matches. Now how about the checksum?
hi = buffer[indexOut++];
lo = buffer[indexOut++];
chk = buffer[indexOut++];
if(chk == (hi ^ lo ^ 0x55)) {
// Checksum looks valid. Get 16-bit LED count, add 1
// (# LEDs is always > 0) and multiply by 3 for R,G,B.
bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L);
bytesBuffered -= 3;
spiFlag = 0; // No data out yet
mode = MODE_HOLD; // Proceed to latch wait mode
// Checksum didn't match; search resumes after magic word.
indexOut -= 3; // Rewind
} // else no header match. Resume at first mismatched byte.
bytesBuffered -= i;
case MODE_HOLD:
if((micros() - startTime) < hold) break; // Still holding; keep buffering
// Latch/delay complete. Advance to data-issuing mode...
mode = MODE_DATA; // ...and fall through (no break):
case MODE_DATA:
while(spiFlag && !(SPSR & _BV(SPIF))); // Wait for prior byte
if(bytesRemaining > 0) {
if(bytesBuffered > 0) {
SPDR = buffer[indexOut++]; // Issue next byte
bytesBuffered--;
bytesRemaining--;
spiFlag = 1;
if((bytesBuffered < 32) && (bytesRemaining > bytesBuffered)) {
hold = 100 + (32 - bytesBuffered) * 10;
mode = MODE_HOLD;
// End of data -- issue latch:
hold = 1000; // Latch duration = 1000 uS
LED_PORT |= LED_PIN; // LED on
mode = MODE_HEADER; // Begin next header search
} // end switch
} // end for(;;)
// Not used. See note in setup() function.
