I am trying my first Arduino project and I am running into problems. I want to run a strand of WS2801's. I can't get the strand to do anything other than the first LED light up. I plan on having 50 total so I have 2 strands and both strands do the same thing so I think it might be something with my setup.
I have Arduino Duemilanove, 25 strand of WS2801 LEDs, 5V 10A power supply.
I have double checked that I have the power correctly wired and think I have them correct. I have also double checked the wiring. I am using the Adafruit library and am using the standard pins they have set of 2 and 3. I have also double checked that my Clock and Data wires are correct.
The very odd thing which makes me think I've done something silly is that when I plug power in to the strand, when I put my hand/fingers next to the wires, the first LED changes colors. That makes me think that it is some sort of wiring issue? Maybe a grounding issue? Both strands do this same thing. I just have no ideas at all...
Any help/suggestions would be appreciated.
(I will get some pictures taken and a video of me touching the wires and having it change colors.)
Thanks,
Zeustopher
