Can't read pin value from interrupt
I'm attaching an interrupt to pin D2, which works fine (I can see that the interrupt is being called. However, I'm unable to read the actual pin state (HIGH/LOW) from within the interrupt. Here is the code:
volatile int pwm_value = 0;
volatile int prev_time = 0;
volatile bool lastState;
  // when pin D2 goes high, call the rising function
  pinMode( 2, INPUT);
  lastState = digitalRead(2);
  attachInterrupt(digitalPinToInterrupt(2), isr, CHANGE);
  Serial.print("PWM: ");
  Serial.print(pwm_value);
  Serial.print("\tLAST: ");
  Serial.println(prev_time);
  delay(100);
void isr() {
  int ts = micros();
  bool state_now = digitalRead(2);
    if (state_now == HIGH) {
      prev_time = ts;
      pwm_value = ts - prev_time;
The call digitalRead(2) in the ISR always returns HIGH (or it simply doesn't work), so I'm unable to detect the end of the pulse. I hope that I'm not doing something stupid here by reading the pin state right after the interrupt is triggered... If not, well, then there must be some bug.
Console output is following:
PWM: 0	LAST: 3198487
PWM: 0	LAST: 3297425
PWM: 0	LAST: 3396332
PWM: 0	LAST: 3495240
PWM: 0	LAST: 3594178
PWM: 0	LAST: 3693085
PWM: 0	LAST: 3792023
If I'm doing something that isn't right, can someone help me with an approach that works, please? Thank you!
So this must definitely be a problem with the Nano BLE, as the same code is running just fine on ESP8266. I wonder if anyone had the same issue...
I used uint32_t instead of int declarations to avoid any unintentional overflows and I added in noInterrupts() at start of isr() code and then Interrupts() at end of the ISR() and it worked (sort of?)... I did try the detachInterrupt() option inside the ISR() but that just froze things up.
gerrikoio:
Thanks for the tips. With these changes, were you able to correctly read a pin value from inside the interrupt? IMO this is very basic functionality, which one can see in tons of examples, so I'm inclined to think that the behaviour I'm observing is one of the quirks of the Arduino wrapper around the mbed OS. Maybe I should move to programming the board in mbed directly, and get rid of these quirks?
Yes it worked, as in pwm_value was updated. As to whether the values were correct, who knows. Anyway, IMHO, I think it is necessary to use noInterrupts() and Interrupts() as "bookends" in any ISR to ensure it functions correctly.
Interesting. However, I have decided to do it in mbed OS. I did some reading, and I like its capabilities. Unfortunately there're almost no examples or documentation around on how to interact with mbed OS from Arduino, and Nano 33 BLE can't be connected from mbed ide directly.
Anyway, at the end it wasn't that hard. Here's the code:
#include <Arduino.h>
#include <pins_arduino.h>
#include <mbed.h>
#include <rtos.h>
#include <PinNames.h>
mbed::Timer timer;
mbed::InterruptIn steeringIn(P1_11);
int32_t begin;
int32_t end;
float distance;
void steering_rise(void);
void steering_fall(void);
  steeringIn.rise(mbed::callback(steering_rise));
  steeringIn.fall(mbed::callback(steering_fall));
  Serial.println("Set up");
void steering_rise(void) {
    timer.reset();
    timer.start();
    begin = timer.read_us();
void steering_fall(void) {
    end = timer.read_us();
    timer.stop();
    distance = end - begin;
  Serial.println(distance);
  wait_us(200);
I'm not saying that the code is final, but it definitely reads and prints the values.
Oh, and BTW, mbed OS has a very nice way how to generate PWM as well
mbed::PwmOut d2(P1_11);
d2.period_ms(200);
d2.pulsewidth_us(1000);
haplm:
Well done. That's really helpful.
I had done some small code experiments using mbed and discovered that many of the #includes you've used such as #include <mbed.h> are already in Arduino.h. Maybe check this out to confirm.
Also you can use namespace, as in "using namespace mbed;", meaning there's no need to use "mbed::" with your mbedos code. I believe, this too may already be included in Arduino. h.
I'll do some cleanup for sure. In the meantime, here's a completely new approach, which is much safer and faster (using EventQueue):
#include <mbed.h>
#include <rtos.h>
#include <mbed_wait_api.h>
#include <mbed_events.h>
//mbed::PwmOut d2(P1_11);
mbed::Timer steeringPulseTimer;
rtos::Semaphore in_steering_sem(1);
events::EventQueue queue(32 * EVENTS_EVENT_SIZE);
rtos::Thread pwmInCallbackThread;
int32_t in_steering_pulse_start;
int32_t in_steering_pulse_end;
int32_t in_steering_pulse_width;
int32_t in_steering_update_ok;
int32_t in_steering_update_failed;
void steering_rise_isr(void);
void steering_fall_isr(void);
void steering_fall_uc(int width);
  steeringPulseTimer.reset();
  // Setup pin D2 (P1_11) to receive steering input
  steeringIn.rise(mbed::callback(steering_rise_isr));
  steeringIn.fall(mbed::callback(steering_fall_isr));
  in_steering_update_ok = 0;
  in_steering_update_failed = 0;
  pwmInCallbackThread.start(mbed::callback(&queue,&events::EventQueue::dispatch_forever));
void steering_rise_isr(void) {
  steeringPulseTimer.start();
void steering_fall_isr(void) {
  steeringPulseTimer.stop();
  queue.call(steering_fall_uc, steeringPulseTimer.read_us());
void steering_fall_uc(int width) {
  bool acq = in_steering_sem.try_acquire_for(2);
  if (acq) {
    in_steering_pulse_width = width;
    in_steering_sem.release();
    in_steering_update_ok++;
  } else in_steering_update_failed++;
  Serial.print("Pulse: ");
  in_steering_sem.acquire();
  Serial.print(in_steering_pulse_width);
  Serial.print("\tacqFails: ");
  Serial.println(in_steering_update_failed);
  wait_us(200000);
I won't post further updates into this thread, but I may post something here: RcCarController/main.cpp at master · haplm/RcCarController · GitHub
Looks good. You've just demonstrated something to me. When reading through your code, I felt that the use of "mbed::" and "rtos::" really helped with understanding where the functions come from.
Thanks.
Yeah, those mbed, rtos, etc spaces help to understand where the functions are coming from. One flaw of the code is that variables in_steering_update_ok and in_steering_update_failed are not thread safe, but since they are just a temporary debug, I didn't bother.
It is going to be interesting when I'll be reading 2 PWM inputs, 7 digital pins, I2C and SPI interfaces, while having to output 2 PWM channels with minimum latency. Well, we will see.
BTW - I've just found that with a programmer, one can use the board in Mbed Studio directly (Mbed OS on Arduino Nano 33 BLE | Djynet). I guess that this is what I'm going to do once I get a programmer...
I've come across the same problem to the original post. It appears to me that interrupts fire ok when using RISING or FALLING but not CHANGE - here they only fire on a rising edge, therefore always reading 1 when reading the pin in the ISR.
gerrikoio:
I adapted the code as suggested but still the same result.
I have added a flag so the output is only printed when the interrupt has fired. Input is a 1Hz square wave from a sig gen (later to be a RC receiver).
My code:
volatile uint pwm_value = 0;
volatile uint prev_time = 0;
volatile int FLAG = LOW;
  pinMode(2, INPUT);
  if (FLAG==HIGH){
    FLAG = LOW;
void isr() {
  noInterrupts();
  FLAG = HIGH;
  int ts = micros();
      prev_time = ts;
  interrupts();
Output with timestamps shows only rising edge triggering the interrupt:
19:10:31.469 -> PWM: 0 LAST: 4474823
19:10:32.486 -> PWM: 0 LAST: 5474884
19:10:33.468 -> PWM: 0 LAST: 6474914
19:10:34.483 -> PWM: 0 LAST: 7474975
19:10:35.466 -> PWM: 0 LAST: 8475036
19:10:36.477 -> PWM: 0 LAST: 9475067
19:10:37.488 -> PWM: 0 LAST: 10475128
19:10:38.472 -> PWM: 0 LAST: 11475189
19:10:39.493 -> PWM: 0 LAST: 12475250
19:10:40.476 -> PWM: 0 LAST: 13475311
19:10:41.469 -> PWM: 0 LAST: 14475342
19:10:42.490 -> PWM: 0 LAST: 15475403
19:10:43.477 -> PWM: 0 LAST: 16475464
Am I missing something here? Same problems on other pins as well. Is there a way to get this to work without doing it in mbed OS?
Thanks for any help!
EDIT: Updated with changes since last release in https://github.com/arduino/ArduinoCore-nRF528x
Seems to be working now...
Ah, nice. So CHANGE is now working? I need to try it... Generally, I have noticed that bugs are being actively worked on, which is good. I have hit something else, and found out that it is already fixed in mbed 6.0 beta 1. Now we just need to wait to ArduinoCore update to mbed 6.0 :slight_smile:
Works for me. Interestingly I've had a real jitter problem that seems to be caused by erroneous readings on the input (pretty sure caused by I terrupt latency) AND by erroneous outputs from servo.write().
I'm not really sure how it relates to the problems encountered here, but I've started a new thread explaining them as it really doesn't fit under this title.
Sure, I'll post the solution for Servo issues there. I have pointe you to this thread because I have mentioned it as well up there, but I agree that this thread is a bit mess.
