Brand new Arduino UNO WiFi R4.
When I plug it into my Mac, the LED matrix displays prettily and ends up as a nice heart.
The yellow LED labelled "L" flashes crisply.
When I press the reset button it all repeats as if I have just turned it on.
If I double-click the reset button the yellow LED fades in and out.
In the IDE, I open the Blink example. It compiles just fine, but will not download.
This is a printout from my serial window:
FQBN: arduino:avr:unowifi
Using board 'unowifi' from platform in folder: /Users/Ralph17/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Using core 'arduino' from platform in folder: /Users/Ralph17/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Detecting libraries used...
/Users/Ralph17/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO_WIFI_DEV_ED -DARDUINO_ARCH_AVR -DESP_CH_UART -DESP_CH_UART_BR=19200 -I/Users/Ralph17/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Ralph17/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/Users/Ralph17/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO_WIFI_DEV_ED -DARDUINO_ARCH_AVR -DESP_CH_UART -DESP_CH_UART_BR=19200 -I/Users/Ralph17/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Ralph17/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/sketch/Blink.ino.cpp -o /private/var/folders/2n/kmz3wpdn3vdg397x7p_s1wmc0000gn/T/315957001/sketch_merged.cpp
/Users/Ralph17/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/2n/kmz3wpdn3vdg397x7p_s1wmc0000gn/T/315957001/sketch_merged.cpp
Compiling sketch...
/Users/Ralph17/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO_WIFI_DEV_ED -DARDUINO_ARCH_AVR -DESP_CH_UART -DESP_CH_UART_BR=19200 -I/Users/Ralph17/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Ralph17/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/sketch/Blink.ino.cpp -o /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /Users/Ralph17/Library/Caches/arduino/cores/arduino_avr_unowifi_e3f7f23ff1056012e50b824d0e6ac716/core.a
Linking everything together...
/Users/Ralph17/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/Blink.ino.elf /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/sketch/Blink.ino.cpp.o /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/../../cores/arduino_avr_unowifi_e3f7f23ff1056012e50b824d0e6ac716/core.a -L/Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC -lm
/Users/Ralph17/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/Blink.ino.elf /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/Blink.ino.eep
/Users/Ralph17/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/Blink.ino.elf /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/Blink.ino.hex
/Users/Ralph17/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /Users/Ralph17/Library/Caches/arduino/sketches/F4F9ABD939AAEC28D02F73D54CB7B7CC/Blink.ino.elf
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Failed uploading: uploading error: exit status 1
I have searched the forums to no avail.
Please help!
Ralph
