I'm trying to flash my leonardo from the command line using avrdude. after numerous programmer not responding errors, I then tried to simply connect to the board with the command:
./avrdude -patmega32u4 -C../etc/avrdude.conf -cavr109 -P/dev/cu.usbmodem...
However, I still get this message:
avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ""; type =
Software Version = .; Hardware Version = .
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
I've tried different leonardos, usb ports, cables, and computers.
Any help with what to try next would be greatly appreciated.
