I got new Arduino Uno r3 board.
Installed latest Arduino IDE 1.6.7
Uploaded latest firmware using ATMEL flip software.
updated Arduino drivers
It assigned com18 in ports
Then opened Arduino IDE
Choosed "Arduino/Genuino Uno" under boards
Choosed "COM18(Arduino/Genuino Uno)" under port
I tried to upload blink LED program example.
It showed an error as such
avrdude: ser_open(): can't open device "\.\COM18": Access is denied.
Please help me.. It's my first time with Arduino and it seems impossible to deal with this
install IDE arduino 1.6.5
remove first all what you have now installed
gonnie08:
I did that.
Again getting the same error message
your com port is not good
select a other????
irwyn
December 26, 2015, 4:52pm
5
Hi I too am a raw beginner and I seem to have exactly the same problem.
I am using Windows 7 Home Premium.
Arduino Uno R3 SMD edition
IDE 1.6.7.
The assigned port is COM7
My error message is
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
The LED 13 on the board flashes when the board is powered up and not connected to the computer. The reset button has no effect on this.
I am following your advise to change the COM port - fingers crossed
I am cheered up to find that I am not alone.
irwyn
December 26, 2015, 7:13pm
6
Cracked it - at least on my machine.
I have loaded an older version.
This time COM8 was assigned to the board and the first run of Blink failed but I received an error option.
I was told that COM1 was being tried and was failing and I was given the option of changing to COM8 which I did and the system is now running fine.
Thanks for your inspiration.
irwyn:
IDE 1.6.7.
My error message is
Select the correct com port under tools>ports
