Can't upload code to ATmega2560 board with USB serial
Hello guys, after following this tutorial: How to Flash Arduino Bootloader without a Programmer – Welldone Blog (fedevel.com) where shows how can I burn the bootloader on my "arduino standalone" board, I'm experiencing an issue while trying to upload a code using Arduino IDE via USB serial to my board, my board is using an ATmega2560 and works similar to an Arduino Mega 2560, I burned the bootloader on the ATmega2560, and the firmware on the ATmega16U2, I can upload the code to my board with the USBasp programmer without problems, but not using the USB cable, So I have two possible theories, 1. I've burned the bootloader with the wrong fuses and bits settings, so maybe the Arduino IDE can not identify the bootloader on the ATmega2560 chip?. The images attached shows the Fuses and Lock Bits settings when I've burned the bootloader, please tell me if I have to change something in it. And the 2. Maybe is something that I have to change in the Arduino IDE settings or files.
This is the error that I see when I try to upload the code, The code I was using to test my board was blink.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 1544 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cstk500v2 -PCOM3 -b115200 -D -Uflash:w:C:\Users\Natanael\AppData\Local\Temp\arduino_build_905806/Blink_hats.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: Unknown
An error occurred while uploading the sketch
option enabled in File -> Preferences.
*Important
  • My ATmega2560 chip was virgin when I bought.
  • My computer identifies my board.
Natanael152:
When you do that, you erase the bootloader. So you always need to burn the bootloader again after uploading via the ISP programmer before you can go back to uploading normally over the Arduino board's USB connection again.
Yeah... I know that, but after that I have burned the bootloader again, so now my ATmega2560 chip is with the bootloader...
Natanael152:
You should use the Arduino IDE to burn the bootloader. That will ensure the fuses are set correctly and the right bootloader is flashed.
You'll probably need to install the right driver for your AVRISP mkII, since the "Jungo" driver used by Atmel Studio is not compatible with the open source AVRDUDE flashing tool the Arduino IDE uses to burn the bootloader. You can use Zadig to install libusbK. If you have troubles after that, try using Zadig to install the libusb-win32 driver instead of libusbK. I have the best results with libusbK, but I remember one or two people who could only get it to work with libusb-win32.
OK, I have already tried that but I tried again, and I used the USBasp that I have to burn the bootloader on it, The AVRISP mkll that you saw was a clone, I've tranformed the ATmega16U2 into a AVRISP clone to use with ATMEL studio, this was in the tutorial that I was following.
So, I have burned the bootloader with USBasp and this was the result message:
         Using Port                    : usb
         Using Programmer              : usbasp
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/stk500v2/stk500boot_v2_mega2560.hex"
avrdude: writing flash (261406 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 261406 bytes of flash written
avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/stk500v2/stk500boot_v2_mega2560.hex:
avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/stk500v2/stk500boot_v2_mega2560.hex:
avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/stk500v2/stk500boot_v2_mega2560.hex contains 261406 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 261406 bytes of flash verified
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: reading on-chip lock data:
avrdude: 1 bytes of lock verified
avrdude done.  Thank you.
And I still can't send code using USB cable.
I have also found that I can make loopback test with my board, but I have never done that, so I have followed the instructions and the letters that I type in the terminal is not echoed back but every time that I type a letter, TX and RX LEDs on my board blinks, So I don't know if my board passed in this test.
