So I have a Uno working well, in which I plugged in a USB Host Shield.
My problem is, when my Uno is alone, everything works fine. But when I try to upload or execute code with my USB host, I'm getting this error at uploading :
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd4
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd4
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I tried uploading the code then plugging in the USB host, but the code doesn't seem to execute (the blink example, well, doesn't blink)
I have the driver up to date for my arduino, which works fine, and via the right COM port.
Well removing the shield works for uploading, but when it comes to executing, I have to plug it in again. And then, no code seems to work, even the blink example. Only the "On" led is turned on.
You need to wire Power Select 2 solder jumpers marked “5V” and “3.3V”. They are used for different power
configurations. The configuration shown, when both jumpers are closed, is suitable for official
Arduinos, such as UNO, Duemilanove, Mega and Mega 2560.
Nevermind, I think I was lost on translation. As iamjirayu said, I wired the 3.3v and 5v connections and it solved the issue. I am still pending to understand how to use the VBUS jumpers, I still don't understand if I need to soler only one of the or do I really need to soler only the 5V one.
