Can't use the Arduino Framework to code STM32F411CEU6
One small issue I have. I have a custom STM32F411CEU6 board, quite similar to the WeAct Black Pill in terms of connections, except for the fact that I have a LED on pin PB13, and whenever I try to blink it using:
while (1)
    /* USER CODE END WHILE */
	 HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_13);
	 HAL_Delay(500);
    /* USER CODE BEGIN 3 */
in the STM32CubeIDE, everything works fine and dandy
The moment i switch to using the Arduino Framework, albeit with the Arduino IDE or PlatformIO, with parameters of:
platform = ststm32
board = genericSTM32F411CE
using the code:
#define LED PB13
  pinMode(LED, OUTPUT);
    digitalWrite(LED, HIGH);
    digitalWrite(LED, LOW);
or anything similar, it just doesn't work! It always says the upload is successful, and it verifies successfully too! But why then, it refuses to work? Any suggestions? I’ve used PB_13, the number 26, PB13 ALT and so on, they just, refuse to work
Hi @BweBweTwe.
I think it will be best to focus on one or the other for now. Trying to cover both Arduino IDE and PlatformIO in our efforts to support you will likely end up causing confusion and thus be counterproductive. It is likely that once you solve the problem for one framework, it will lead you to the solution in the other. If not, you can always transition the discussion to focus on the problem as it occurs for the other framework once the problem is solved for the first one.
I suspect that you don't actually intend to use both Arduino IDE and PlatformIO, but instead only tried both in hopes one of the two would work. If so, please tell us which of the two you prefer to use.
If you don't have a preference, or if you actually do plan to use both, then I recommend we start by focusing on Arduino IDE. Some of the forum helpers do use PlatformIO, but there is more expertise here for Arduino IDE. So I think the likelihood of finding a solution here is higher for Arduino IDE.
Yes please! I'd like to know how can i get my board working with the Arduino IDE :)
I'm going to ask you to provide the full verbose output from a compilation.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Open the sketch in Arduino IDE.
  2. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  3. Check the box next to "Show verbose output during: ☐ compile" in the "Preferences" dialog.
  4. Click the "OK" button.
    The "Preferences" dialog will close.
  5. Select Sketch > Verify/Compile from the Arduino IDE menus.
  6. Wait for the compilation to finish.
  7. Right click (Control-click for macOS users) on the black "Output" panel at the bottom of the Arduino IDE window.
    A context menu will open.
  8. Select Copy All from the menu.
  9. Open a reply here on this forum topic by clicking the "Reply" button.
  10. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  11. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  12. Move the cursor outside of the code block markup before you add any additional text to your reply.
  13. Click the "Reply" button to publish the post.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a reply here on this forum topic by clicking the "Reply" button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
