Programming of ESP8266 mini with Arduino 2.3 does not work
Programming of ESP8266 mini with IDE 18.19 works correctly but
with version Arduino 2.3.10 NOT!
(tested different versions 2.3.x)
Same computer, same USB Port!
Tested different solutions with
changing USB port
changing USB cable
different upload speed
all not working with version 2.3.x
settings are the same in version 1.8.19 and 2.3.10 (also installed library for 8266)
ERROR:
A fatal esptool.py error occurred: Failed to write to target RAM (result was 0107)
With Arduino 1.8.19 the target programming works perfectly and the ESP8266 mini works fine!
What is here the problem of arduino version 1.8.19 and 2.3.x
I more than likely can not help you but I have a question.
Is the IDE 1.8.19 a portable installation? If so, the ESP8266 board package might be different.
Does this happen with any sketch that you try to upload?
It's not a library :wink: Unless we're talking about different things).
  1. I installed the version 2.3.10 with library ESP8266 not working
  2. then I tried the legacy version 1.8.19 installed on the same computer (windows 11) with
    same library path of esp8266 in the preferences settings.
version 1.8.19 works, version 2.3.10 NOT
and yes I tried different sketch and I tried also different ESP8266 mini modules
USB driver of ESP8266 is FTDI newest driver from windows and is detected correctly,
it works with version 1.8.19 !!!
I also installed the version 2.3.10 on a laptop (windows10), also not working, with
same error message
Hi @torquayn. I believe you are being affected by the bug tracked here:
That bug is caused by a helper tool used by Arduino IDE 2.x, which is named serial-discovery. A change in the behavior of the latest version of that tool causes it to interfere with the upload under certain conditions.
The developers have already prepared a fix for that bug. I'll provide instructions you can follow to replace the bad installation of serial-discovery with the fixed version:
  1. If Arduino IDE 2.3.10 is running, select File > Quit from the Arduino IDE menus.
    All Arduino IDE windows will close.
  2. Start Windows File Explorer.
  3. Use File Explorer to navigate to the folder at the following path on your computer's hard drive:
    C:\Users\<username>\AppData\Local\Arduino15\packages\builtin\tools\serial-discovery\1.5.0
    (where <username> is your Windows username)
    • :red_exclamation_mark: The AppData folder is hidden by default. You can make it visible by opening the "View" menu in File Explorer, then checking the box next to "☐ Hidden items".
  4. You will see a file named serial-discovery.exe in the folder. Right click on that file.
    A context menu will open.
  5. Select "Rename" from the menu.
    The menu will close and the filename will now be an editable text field.
  6. Type serial-discovery-original in the text field.
  7. Press the Enter key.
    The filename change will be committed.
  8. Click the following link to download the fixed version of serial-discovery:
    serial-discovery_test-13c959e7be4f01527db4d60fbabfa180616cf0c8-git-snapshot_Windows_64bit.zip (2.2 MB)
  9. Wait for the download to finish.
  10. Extract the downloaded serial-discovery_test-13c959e7be4f01527db4d60fbabfa180616cf0c8-git-snapshot_Windows_64bit.zip file to any convenient location on your computer.
  11. Copy the serial-discovery.exe file from the extracted folder to the folder at the following path on your hard drive:
Now start Arduino IDE 2.3.10 and try uploading again, just as you did before when you encountered the error. Hopefully it will be successful this time.
Please let us know if you have any questions or problems while following those instructions. Please also post a reply here to let us know if this does fix the error for you. That feedback will be very useful for validating the fix. We are not able to reproduce the error, so we are dependent on the feedback from affected users like you.
Hello ptillisch
THX for your help, thats was the problem, it compiles and writes the sketch on the ESP8266
correctly and it runs.
Thanks for you great help
best regards :--))
You are welcome. I'm glad it is working now.
Thanks so much for taking the time to post an update. I notified the developer of the results of your test of the prospective fix they prepared.
Regards, Per
(post deleted by author)
