Capteur effet Hall
My name is Alexandre
i am French
I have a problem about the topic effect sensor for my project.
here is the link of the sensor:
I have to measure the current flowing in an engine and in a photovoltaic panel and I am a little lost to start my program is still calculating to go from running to a voltage because the arduino card does not work when voltage.
Thank you for your help.
This sounds like a bad Google translation. You're writing about a program you have but I cannot find the source in your post. Post that code (and don't forget to use code tags, that's the </> button in the editor) and describe the problem in more detail, try simple sentences if your use Google translator.
