Ciao
sto usando il programma di esempio incluso nella libreria LiquidCrystal, con gli schemi delle schede di pighixxx,con un display 16x2 ma ho problemi di visualizzazione dei primi 8 caratteri sulle due righe, ho scoperto che se commento questa riga
//lcd.begin(16, 2);
i caratteri vengono visualizzati bene ma non riesco a posizionare diversamente il cursore
avete suggerimenti
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
Controlla le serigrafie sul retro del display con i segnali elencati nel tuo esempio.
The circuit:
ciao
aggiorno dicendo che
ho provato ad alimentarlo separatamente ma niente da fare, le prime 8 colonne continuano ad essere scarsamente visibili, ho fatto prove anche collegando tutti i pin dati ma senza risultati, quello che non capisco è che lo stesso problema si presenta con display di due marche diverse mentre una terza marca non mi da questi problemi
secondo me non hai collegato correttamente il cntrasto o uno dei pin di massa. Non potresti almeno spiegare che collegamenti ai fatto così ci possiamo sincerare che sia tutto a posto?
come detto ho seguito lo schema fornito dalle schede di pighixxx confrontato anche con quello fornito dal Learning, i collegamenti passano da breadboard, può essere un problema di collegamenti, avevo già letto di questo problema, ma con tre marche diverse solo con due ho questo problema con un terzo tipo non mi da questo problema
leo72:
stefa24:
//lcd.begin(16, 2);
Questo ti serve per inizializzare la libreria e dirgli com'è il display.
PS:
hai provato a far lavorare il display ad 8 bit invece che a 4 bit?
si so che serve ad inizializzare il lcd, ho solo notato che se lo commento i caratteri vengono visualizzati correttamente anche se si perde la possibilità di posizionare il cursore, avevo già provato con 8 bit ma senza risultato, riprovo forse ho fatto male i collegamenti
grazie per le risposte
Stefano
PS: forse mi sono imbattuto in 2 display difettosi, ma prima di comprarne altri volevo essere sicuro
O forse hai dei display che non rispettano la piedinatura standard.
Io ne ho 3 e uno di questi NON rispetta la solita piedinatura. Per fortuna il venditore forniva il datasheet e da li vidi che non era la solita.
