According to In-Depth Tutorial to Interface Micro SD Card Module with Arduino
it should be under File > Examples > SD > CardInfo. But it's not there? SD card library is built-in right?
I'm using 2.3.1 Arduino IDE with Arduino UNO
Yes, it should be there:
Do you see entries for other libraries in the File > Examples menu, or is is only the "Built-in examples"?
If so, is there a File > Examples > SD entry in the menu, or are all the "SD" library examples missing rather than "CardInfo" only?
It is automatically installed the first time you start Arduino IDE after a fresh installation.
