SD library: CardInfo
I am using an SD card adapter for my Arduino Mega but everytime I try to run the CardInfo example all I get is this message.
Inig SD card...InitSD card...
Inig SD card...
I've formatted the SD card, I've checked the wiring, I've checked if it's going to the right pins, I've tried multiple cards and adapters. I don't understand why it can't detect the card.
Which SD card adapter are you using?
How is it connected to the Mega?
Some use D4 as CS. Others use D10.
You are aware that the SPI pins on a Mega are not on pins 11/12/13?
For some reason this has happened to me, too. An easy solution would be using SdFat.h. It has more functionality compared to the default SD.h, including the option to format the SD card using the Arduino board. Since I've used it, this never happened...
Side-note
Yes, I've used an Arduino Mega 2560 (clone, actually), but instead of an SD card, this happened to my MicroSD card...
Yes, I have them wired in the correct spots.
I've tried using SdFat.h but I'm still getting the same problem.
SD initialization failed.
Do not reformat the card!
Is the card correctly inserted?
Is there a wiring/soldering problem?
Is SD_CS_PIN set to the correct value?
Does another SPI device need to be disabled?
SD errorCode: SD_CARD_ERROR_INVALID_CARD_CONFIG = 0x2b
SD errorData = 0x0
This is the error I receive now
Let's put everything back to normal and follow these steps (Even if you've done some of them, it's recommended to read them again):
  1. Check the wiring: The correct wiring for an SD card module would be:
    • CS->4
    • MISO->50
    • MOSI->51
    • SCK->52
  2. Upload the following code (It's the SdInfo.ino example but I modified it):
 * This program attempts to initialize an SD card and analyze its structure.
 * The CID and CSD registers are also printed in HEX for use in online
 * decoders like these.
 * https://gurumeditation.org/1342/sd-memory-card-register-decoder/
 * https://archive.goughlui.com/static/multicid.htm
#include "SdFat.h"
#include "sdios.h"
  Set DISABLE_CS_PIN to disable a second SPI device.
  For example, with the Ethernet shield, set DISABLE_CS_PIN
  to 10 to disable the Ethernet controller.
const int8_t DISABLE_CS_PIN = -1;
  Change the value of SD_CS_PIN if you are using SPI
  and your hardware does not use the default value, SS.
  Common values are:
  Arduino Ethernet shield: pin 4
  Sparkfun SD shield: pin 8
  Adafruit SD shields and modules: pin 10
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
const uint8_t SD_CS_PIN = 4;
// Try to select the best SD card configuration.
#if HAS_SDIO_CLASS
#define SD_CONFIG SdioConfig(FIFO_SDIO)
#elif ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SD_SCK_MHZ(16))
#else  // HAS_SDIO_CLASS
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SD_SCK_MHZ(16))
#endif  // HAS_SDIO_CLASS
SdFs sd;
cid_t cid;
csd_t csd;
scr_t scr;
uint8_t cmd6Data[64];
uint32_t eraseSize;
uint32_t ocr;
static ArduinoOutStream cout(Serial);
void cidDmp() {
  cout << F("\nManufacturer ID: ");
  cout << uppercase << showbase << hex << int(cid.mid) << dec << endl;
  cout << F("OEM ID: ") << cid.oid[0] << cid.oid[1] << endl;
  cout << F("Product: ");
  for (uint8_t i = 0; i < 5; i++) {
    cout << cid.pnm[i];
  cout << F("\nRevision: ") << cid.prvN() << '.' << cid.prvM() << endl;
  cout << F("Serial number: ") << hex << cid.psn() << dec << endl;
  cout << F("Manufacturing date: ");
  cout << cid.mdtMonth() << '/' << cid.mdtYear() << endl;
  cout << F("CID HEX: ");
  hexDmp(&cid, sizeof(cid));
void clearSerialInput() {
  uint32_t m = micros();
  do {
    if (Serial.read() >= 0) {
      m = micros();
  } while (micros() - m < 10000);
void csdDmp() {
  eraseSize = csd.eraseSize();
  cout << F("\ncardSize: ") << 0.000512 * csd.capacity();
  cout << F(" MB (MB = 1,000,000 bytes)\n");
  cout << F("flashEraseSize: ") << int(eraseSize) << F(" blocks\n");
  cout << F("eraseSingleBlock: ");
  if (csd.eraseSingleBlock()) {
    cout << F("true\n");
    cout << F("false\n");
  cout << F("dataAfterErase: ");
  if (scr.dataAfterErase()) {
    cout << F("ones\n");
    cout << F("zeros\n");
  cout << F("CSD HEX: ");
  hexDmp(&csd, sizeof(csd));
void errorPrint() {
  if (sd.sdErrorCode()) {
    cout << F("SD errorCode: ") << hex << showbase;
    printSdErrorSymbol(&Serial, sd.sdErrorCode());
    cout << F(" = ") << int(sd.sdErrorCode()) << endl;
    cout << F("SD errorData = ") << int(sd.sdErrorData()) << dec << endl;
void hexDmp(void* reg, uint8_t size) {
  uint8_t* u8 = reinterpret_cast<uint8_t*>(reg);
  cout << hex << noshowbase;
  for (size_t i = 0; i < size; i++) {
    cout << setw(2) << setfill('0') << int(u8[i]);
  cout << dec << endl;
bool mbrDmp() {
  MbrSector_t mbr;
  bool valid = true;
  if (!sd.card()->readSector(0, (uint8_t*)&mbr)) {
    cout << F("\nread MBR failed.\n");
    errorPrint();
    return false;
  cout << F("\nSD Partition Table\n");
  cout << F("part,boot,bgnCHS[3],type,endCHS[3],start,length\n");
  for (uint8_t ip = 1; ip < 5; ip++) {
    MbrPart_t* pt = &mbr.part[ip - 1];
    if ((pt->boot != 0 && pt->boot != 0X80) ||
        getLe32(pt->relativeSectors) > csd.capacity()) {
      valid = false;
    cout << int(ip) << ',' << uppercase << showbase << hex;
    cout << int(pt->boot) << ',';
    for (int i = 0; i < 3; i++) {
      cout << int(pt->beginCHS[i]) << ',';
    cout << int(pt->type) << ',';
      cout << int(pt->endCHS[i]) << ',';
    cout << dec << getLe32(pt->relativeSectors) << ',';
    cout << getLe32(pt->totalSectors) << endl;
  if (!valid) {
    cout << F("\nMBR not valid, assuming Super Floppy format.\n");
  return true;
void dmpVol() {
  cout << F("\nScanning FAT, please wait.\n");
  int32_t freeClusterCount = sd.freeClusterCount();
  if (sd.fatType() <= 32) {
    cout << F("\nVolume is FAT") << int(sd.fatType()) << endl;
    cout << F("\nVolume is exFAT\n");
  cout << F("sectorsPerCluster: ") << sd.sectorsPerCluster() << endl;
  cout << F("fatStartSector:    ") << sd.fatStartSector() << endl;
  cout << F("dataStartSector:   ") << sd.dataStartSector() << endl;
  cout << F("clusterCount:      ") << sd.clusterCount() << endl;
  cout << F("freeClusterCount:  ");
  if (freeClusterCount >= 0) {
    cout << freeClusterCount << endl;
    cout << F("failed\n");
    errorPrint();
void printCardType() {
  cout << F("\nCard type: ");
  switch (sd.card()->type()) {
    case SD_CARD_TYPE_SD1:
      cout << F("SD1\n");
    case SD_CARD_TYPE_SD2:
      cout << F("SD2\n");
    case SD_CARD_TYPE_SDHC:
      if (csd.capacity() < 70000000) {
        cout << F("SDHC\n");
        cout << F("SDXC\n");
    default:
      cout << F("Unknown\n");
void printConfig(SdSpiConfig config) {
  if (DISABLE_CS_PIN < 0) {
    cout << F(
        "\nAssuming the SD is the only SPI device.\n"
        "Edit DISABLE_CS_PIN to disable an SPI device.\n");
    cout << F("\nDisabling SPI device on pin ");
    cout << int(DISABLE_CS_PIN) << endl;
    pinMode(DISABLE_CS_PIN, OUTPUT);
    digitalWrite(DISABLE_CS_PIN, HIGH);
  cout << F("\nAssuming the SD chip select pin is: ") << int(config.csPin);
  cout << F("\nEdit SD_CS_PIN to change the SD chip select pin.\n");
void printConfig(SdioConfig config) {
  (void)config;
  cout << F("Assuming an SDIO interface.\n");
  // Wait for USB Serial
  while (!Serial) {
    yield();
  cout << F("SdFat version: ") << SD_FAT_VERSION_STR << endl;
  printConfig(SD_CONFIG);
  // Read any existing Serial data.
  clearSerialInput();
  // F stores strings in flash to save RAM
  cout << F("\ntype any character to start\n");
  while (!Serial.available()) {
    yield();
  uint32_t t = millis();
  if (!sd.cardBegin(SD_CONFIG)) {
    cout << F(
        "\nSD initialization failed.\n"
        "Do not reformat the card!\n"
        "Is the card correctly inserted?\n"
        "Is there a wiring/soldering problem?\n");
    if (isSpi(SD_CONFIG)) {
      cout << F(
          "Is SD_CS_PIN set to the correct value?\n"
          "Does another SPI device need to be disabled?\n");
    errorPrint();
    return;
  t = millis() - t;
  cout << F("init time: ") << dec << t << " ms" << endl;
  if (!sd.card()->readCID(&cid) || !sd.card()->readCSD(&csd) ||
      !sd.card()->readOCR(&ocr) || !sd.card()->readSCR(&scr)) {
    cout << F("readInfo failed\n");
    errorPrint();
    return;
  printCardType();
  cout << F("sdSpecVer: ") << 0.01 * scr.sdSpecVer() << endl;
  cout << F("HighSpeedMode: ");
  if (scr.sdSpecVer() > 101 && sd.card()->cardCMD6(0X00FFFFFF, cmd6Data) &&
      (2 & cmd6Data[13])) {
  cidDmp();
  csdDmp();
  cout << F("\nOCR: ") << uppercase << showbase;
  cout << hex << ocr << dec << endl;
  if (!mbrDmp()) {
    return;
  if (!sd.volumeBegin()) {
    cout << F("\nvolumeBegin failed. Is the card formatted?\n");
    errorPrint();
    return;
  dmpVol();
It should work now...
