system
July 28, 2011, 12:52pm
1
Hi, i have a problem.
I'm using Ubuntu linux and arduino duemilanove.
I have code for console program, which catch every serial input (from arduino).
#include <fcntl.h>
#include <stdio.h>
#include <termios.h>
#include <stdlib.h>
#include <strings.h>
#define SPEED B9600
#define PORT "/dev/ttyUSB0"
int main( ){
int fd = open( PORT, O_RDONLY | O_NOCTTY );
if (fd <0) {perror(PORT); exit(-1); }
struct termios options;
bzero(&options, sizeof(options));
options.c_cflag = SPEED | CS8 | CLOCAL | CREAD | IGNPAR;
tcflush(fd, TCIFLUSH);
tcsetattr(fd, TCSANOW, &options);
int r;
char buf[255];
while( 1 ){
r = read( fd, buf, 255 );
buf[r]=0;
printf( "%s", buf );
And when i press some button on my arduino, it sends Serial.println("1"); code "1" to serial port.
So, i need to add some code to upper part to catch this (code "1") and launch some application, for example.
I tried
int r;
char buf[255];
while( 1 ){
if (strcmp(buf, "1")==0) {
printf("gotcha");
buf[r]=0;
or just
if (buf=="1") {
printf("gotcha");
it's not working for me
Anybody can help me catch and compare this ?
system
July 28, 2011, 3:30pm
2
printf("gotcha");
buf[r]=0;
The strcmp() function expects the input array to be NULL terminated. You should be adding the NULL terminator first, then calling strcmp().
system
July 28, 2011, 4:13pm
3
PaulS:
i had a same problem)
thanks!
2all:
just needed to add
if (strcmp(buf, "1\0")==0) {
printf("gotcha");
system
July 28, 2011, 4:25pm
4
The \0 is redundant.
system
July 29, 2011, 9:57am
5
But there is one big problem:
when this program is running, cpu have 100% load.
how can it be helped?
system
July 29, 2011, 8:59pm
6
It can't. The Arduino runs flat out, as fast as it can, all the time. Even when it is accomplishing nothing.
What is the real problem you are trying to solve. Reducing CPU load on a single core processor isn't the solution to that problem.
system
July 31, 2011, 4:00pm
7
PaulS
BUT, when you listening serial port with Arduino IDE, it takes about 5-7% CPU
system
July 31, 2011, 4:06pm
8
How have you measured this? How is it related to whatever problem you are trying to solve?
Serial data is collected in an interrupt handler. The Serial.available() function is used to determine if the interrupt handler has been fired to collect some data. So, the Arduino isn't really ACTIVELY listening for serial data, any more than you actively listen for a phone to ring.
I can only assume that the CPU utilization in that post refers to the PC rather than the Arduino
system
August 1, 2011, 5:59pm
10
so, here some screens.
idle:
Arduino IDE:
this program:
I don't know what it actually mean, but i will try to fix cpu usage problem.
When i'll get solution, i post it
